Vista Crashes when Changing/Adjusting Sound
  1. #1
    pitseleh21 Guest
    I've been having this problem for about a week with Windows Vista
    32bit where the computer freezes if I try to adjust the sound. It
    happens when changing the volume through the Vista sound icon, in
    Windows Media Player, or when using the volume keys on the keyboard. I
    believe it started after my computer locked up and I had Windows Media
    Player open and playing sound.
    The system doesn't usually full freeze though, so I can still Control-
    Alt-Delete to the Vista screen and I am able to load Task Manager, but
    I can't click on anything (either the taskbar or any open windows).
    The Alt-Tab window also opens but won't switch between windows.
    Sometimes I can logoff from the Ctrl-Alt-Delete screen, but sometimes
    I have to hard reboot the computer.
    The computer I'm using is a Dell Latitude laptop, with the 'Sigmatel
    High Definition Audio'. It came with Vista installed already.
    So far, I've tried uninstalling and reinstalling the sound card
    drivers, using both the drivers found by Windows and the drivers that
    Dell has on their website. I've also tried a registry cleaner type
    program in case something became corrupted but that didn't help
    either. I'm thinking at this point reformatting is my only option, but
    hopefully I've missed something so that I don't have to go down that
    road.
    Any help would be much appreciated. Thanks.
  2. #2
    Andre Da Costa[ActiveWin] Guest
    Re: Vista Crashes when Changing/Adjusting Sound
    You probably need to contact Dell support about this one since it might a
    problem with their device drivers.
    Andre
    Blog: http://adacosta.spaces.live.com
    My Vista Quickstart Guide:
    http://adacosta.spaces.live.com/blog...3DB!9709.entry
    <pitseleh21@xxxxxx> wrote in message
    news:5dd375d3-55ab-4deb-ad51-ace28e7aa008@xxxxxx
    > Hi,
    > road.
Vista Crashes when Changing/Adjusting Sound problems?
Solved No "Ding" Sound when Adjusting Volume In Tray therock Sound & Audio 3 03 Jun 2009
Vista Crashes When Changing Wireless Network Henok Vista General 8 30 Jun 2008
iTunes sound crashes.... solacim Vista General 1 29 May 2008
Sound Recorder - adjusting levels Old Derbeian Vista music pictures video 0 16 Feb 2008
adjusting left/right sound van Vista General 1 16 Dec 2007
