Vista - A New Problem I am Having with Build 5308 CTP: No Programs will install on it (Except MBC)!
Old 04-18-2006   #1 (permalink)
Kevin John Panzke
it (Except MBC)!
Old 04-18-2006   #2 (permalink)
Zack Whittaker
Re: A New Problem I am Having with Build 5308 CTP: No Programs will install on it (Except MBC)!
Disable UAP:
http://www.vistabase.co.uk/welcome.p...ity/disableuap
and also ensure that the applications are running in XP SP2 compatibility
mode if necessary.
Zack Whittaker
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--: Original message follows :--
"Kevin John Panzke" <admin@nospam.kevinpanzke.com> wrote in message
news:uAgoAdtYGHA.4836@TK2MSFTNGP05.phx.gbl...
>it (Except MBC)!
Old 04-18-2006   #3 (permalink)
Kevin John Panzke
This issue only existed in my two most recent Build 5308 CTP installs, so
therefore I have filed a Bug Report on it.
"Zack Whittaker" <admin@zacknet.co.uk> wrote in message
news:uf084itYGHA.3848@TK2MSFTNGP05.phx.gbl...
> Disable UAP:
> mode if necessary.
> Zack Whittaker
> not
> that up!
>>on it (Except MBC)!
Old 04-18-2006   #4 (permalink)
Kevin John Panzke
P.S. I also filed a New Bug Report about the fact that the Windows Vista
Build 5308 CTP Windows Update Program is not working again!
news:euOqvstYGHA.3328@TK2MSFTNGP02.phx.gbl...
>> Disable UAP:
>> mode if necessary.
>> Zack Whittaker
>> not
>> that up!
>>>on it (Except MBC)!
Old 04-18-2006   #5 (permalink)
Andre Da Costa [Extended64]
This information is really off the ball, I use standard Admin account Vista
and I have never had to disable UAP to send in a report or set anything to
XP Compatibility mode. It possible that MBC is just experiencing technical
difficulties at the moment or he needs to simply update the client or
reinstall it.
Andre
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
FAQ for MS AntiSpy http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
> Disable UAP:
> mode if necessary.
> Zack Whittaker
> not
> that up!
>>on it (Except MBC)!
Old 04-18-2006   #6 (permalink)
Kevin John Panzke
Andre, I said that no programs will install on Windows Vista Build 5308 CTP
(except MBC which installs just fine on Build 5308 CTP, otherwise I would
not have been able to file 2 Bug Reports in a Row 1 Hour Ago).
"Andre Da Costa [Extended64]" <andred25@hotmail.com> wrote in message
news:%23SgHDPvYGHA.4760@TK2MSFTNGP03.phx.gbl...
> Vista and I have never had to disable UAP to send in a report or set
> anything to XP Compatibility mode. It possible that MBC is just
> experiencing technical difficulties at the moment or he needs to simply
> update the client or reinstall it.
> Andre
>> Disable UAP:
>> mode if necessary.
>> Zack Whittaker
>> not
>> that up!
>>>on it (Except MBC)!
Old 04-18-2006   #7 (permalink)
Kevin John Panzke
Now it (Build 5308 CTP Windows Update) is working, however it is stuck at 0%
complete.
news:%23ZfOy3tYGHA.3328@TK2MSFTNGP02.phx.gbl...
>>> Disable UAP:
>>> compatibility mode if necessary.
>>> Zack Whittaker
>>> not
>>> cleared
>>> that up!
>>>>on it (Except MBC)!
Old 04-18-2006   #8 (permalink)
Kevin, stop filing bugs, because they will just be ignored anyway. You have
to be in the technical beta program. Microsoft has a select group of testers
for feedback on Vista and Longhorn Server.
Andre
news:OfZhwpvYGHA.3328@TK2MSFTNGP02.phx.gbl...
> CTP (except MBC which installs just fine on Build 5308 CTP, otherwise I
> would not have been able to file 2 Bug Reports in a Row 1 Hour Ago).
>> Andre
>>> Disable UAP:
>>> Zack Whittaker
>>> not
>>> cleared
>>> that up!
>>>>on it (Except MBC)!
Old 04-18-2006   #9 (permalink)
Zack Whittaker
Actually anyone can file a bug Andre, and they're just as important as any
other bug they receive.
Zack Whittaker
that up!
news:%23$tFXyvYGHA.1348@TK2MSFTNGP05.phx.gbl...
> have to be in the technical beta program. Microsoft has a select group of
> testers for feedback on Vista and Longhorn Server.
> Andre
>>> Andre
>>>> Disable UAP:
>>>> Zack Whittaker
>>>> and not
>>>> cleared
>>>> that up!
Old 04-18-2006   #10 (permalink)
No, they are not, the Windows Team does not look into these reports.
Andre
news:O2MWonwYGHA.3400@TK2MSFTNGP02.phx.gbl...
> Zack Whittaker
> not
> that up!
>> Andre
>>>> Andre
>>>> FAQ for MS AntiSpy
>>>>> Disable UAP:
>>>>> Zack Whittaker
>>>>> and not
>>>>> cleared
>>>>> that up!
Vista 5308 Build Install Times Vista General
Vista 5308 and Sound Blaster Live 24 bit install problem Vista installation & setup
CD Burning in Vista Build 5308 Vista General
Reboot & build 5308 crashes Vista installation & setup
MSXML 4.0 will not install on Build 5308 Vista General
