Vista - help with the snippinf tool
Old 12-06-2007   #1 (permalink)
jon e
I am having trouble with the snipping tool. It won't copy automatically
or when you mouse/click the copy icon on the toolbar. It WILL save to a
file. It won't send by e-mail using either option.
Any solutions would be appreciated
jon e
Old 12-07-2007   #2 (permalink)
Ronnie Vernon MVP
Re: help with the snippinf tool
Jon
What do you use for your default email program? If the email option doesn't
work with the Snipping Tool, just save the snip as a file and attach the
file to an email in whatever email program you use.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
"jon e" <jone@xxxxxx> wrote in message
news:9557AE81-35AC-4B18-8ACA-90F96833597B@xxxxxx
> jon e
Old 12-08-2007   #3 (permalink)
jon e
thank you! I'm using yahoo mail-- but also-- the copy icon is not active as
well-- and doubt if that is a problem brought about by my default mail??
Any other ideas.
Thanks
jon e
"Ronnie Vernon MVP" wrote:
Quote:
> Jon
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
> > jon e
Old 12-08-2007   #4 (permalink)
Silver Surfer
Hope someone can address this problem. My snip tool exhibits the exact same
behavior as you describe. My default email is Windows Mail.
news:04C3A189-0057-4470-87B7-366A5333EC80@xxxxxx
> as
> Any other ideas.
> Thanks
> jon e
Quote:
>> Jon
>> doesn't
>> Ronnie Vernon
>> Microsoft MVP
>> Windows Shell/User
>> > jon e
Old 12-09-2007   #5 (permalink)
Ronnie Vernon MVP
Jon
Make sure that everything is configured properly.
Start the Snipping Tool.
Click on 'Options'.
Make sure that all of the options are selected.
Click the 'New' drop down menu.
Select 'Free form snip'.
The screen should dim and mouse cursor will be replaced by a scissor icon.
Hold down the left mouse button and drag to make your selection.
When you release the mouse but5ton a new dialog box should appear with your
selection showing. Select File/Save As and save the image file to the
Desktop.
Open your email program, create a new message and attach the image file to
the message.
Does this work?
Ronnie Vernon
Microsoft MVP
Windows Shell/User
> as
> Any other ideas.
> Thanks
> jon e
Quote:
>> Jon
>> doesn't
>> Ronnie Vernon
>> Microsoft MVP
>> Windows Shell/User
>> > jon e
Old 12-09-2007   #6 (permalink)
Vista Ultimate x64
Hehe, you guys have it easy - at least your snipping tool works.
As soon as I start mine, all three of my monitors go WHITE. I can't see what I'm snipping.
WEIRD.
Old 12-09-2007   #7 (permalink)
Vista Ultimate x64
Ok, I played around with the options, and the white screen seems to have disappeared.
Old 12-09-2007   #8 (permalink)
jon e
sorry that I misspelled SNIPPING tool
Yes-- I had gone through ALL those things before I had asked for help.
Simply put-- the copy and the e-mail functions are not active--- period! In
any form of free hand or rectangular snip. I can save to a file-- but would
like it to function like it is supposed to.
Jon
jon e
Quote:
> Jon
> Click on 'Options'.
> Desktop.
> the message.
> Does this work?
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
> > as
> > Any other ideas.
> > Thanks
> > jon e
Quote:
> >> Jon
> >> doesn't
> >> Ronnie Vernon
> >> Microsoft MVP
> >> Windows Shell/User
> >> > jon e
No Tool Bar Vista mail
tool bar changes Vista General
WM tool bar Vista mail
MW tool bar Vista mail
WMP 11 tool bar Vista General
