| | Is there a simple way to hide a hard drive? Vista Ultimate 64bit Is there a way to hide drives in Vista? I see aftermarket utilities, but I'd rather discover a native Vista way to do it. Back in the 'old days', I used a third party utility to password protect a drive and was never able to access it again - IM -- USA - Washington State, Kitsap County "Replies welcomed as a sign of good etiquette" Nostradamus 1560 |
| | Re: Is there a simple way to hide a hard drive? In Disk Management, unassigned a drive letter. I Bleed Blue and Gold GO BEARS! "Imageman" <Imageman@xxxxxx> wrote in message news:5PKdne08bc3gm8XanZ2dnUVZ_rSrnZ2d@xxxxxx Quote: > Vista Ultimate 64bit > > Is there a way to hide drives in Vista? I see aftermarket utilities, but I'd > rather discover a native Vista way to do it. Back in the 'old days', I used a > third party utility to password protect a drive and was never able to access > it again - IM > > -- > USA - Washington State, Kitsap County "Replies welcomed as a sign of good > etiquette" Nostradamus 1560 > > > |
| | Re: Is there a simple way to hide a hard drive? Imageman wrote: Quote: > Vista Ultimate 64bit > > Is there a way to hide drives in Vista? I see aftermarket utilities, > but I'd rather discover a native Vista way to do it. Back in the 'old > days', I used a third party utility to password protect a drive and > was never able to access it again - IM > to store my password files. It's free and I've not had moment's problem with it. Dave |
| | RE: Is there a simple way to hide a hard drive? Yes, there is. from http://www.howtogeek.com/tag/windows-vista/ where there are loads of neato tips http://www.howtogeek.com/howto/windo...windows-vista/ Hope that helps! -Phil "Imageman" wrote: Quote: > Vista Ultimate 64bit > > Is there a way to hide drives in Vista? I see aftermarket utilities, but I'd > rather discover a native Vista way to do it. Back in the 'old days', I used > a third party utility to password protect a drive and was never able to > access it again - IM > > -- > USA - Washington State, Kitsap County "Replies welcomed as a sign of good > etiquette" Nostradamus 1560 > > > > |
| | Re: Is there a simple way to hide a hard drive? In article <5PKdne08bc3gm8XanZ2dnUVZ_rSrnZ2d@xxxxxx>, Imageman <Imageman@xxxxxx> wrote: Quote: > >Is there a way to hide drives in Vista? (That's an old joke :-) |
| | #6 (permalink) |
| | Re: Is there a simple way to hide a hard drive? If you have sensitive or important data stored on a particular disk drive that you don’t want anyone to see, a great way to hide it is to remove the drive letter assigned to a particular mounted volume. With Windows , you can achieve this easily using nothing more than the Command Prompt. Here's how: - Click Start -> Run (This brings up the Run dialog box) - Type cmd and press Enter (This brings up the Windows Command Prompt) - Type diskpart in the command prompt and press Enter (This launches the Diskpart utility within the Command Prompt window) - Now type list volume (This displays a list of all mounted volumes on your computer and their associated drive letters) - Using the above picture as reference, if, for example, you would like to hide drive E, type select volume 6 - Now type remove letter E (Note: This sometime requires a reboot) Diskpart will now remove the drive letter. The drive will no longer be available via Windows Explorer or My Computer. Don’t worry though, your data remains safe! Now, should you want to unhide the drive and make it accessible again, just repeat the above process. But instead of typing remove letter E, type assign letter E -- Cinmute ------------------------------------------------------------------------ Cinmute's Profile: http://forums.techarena.in/members/104538.htm View this thread: http://forums.techarena.in/vista-help/866432.htm http://forums.techarena.in |
| Re: Drive - Hide | Vista security | |||
| Hard drive light constantly flashing ,reading hard drive during id | Vista hardware & devices | |||
| Vista newbie: trying to add a simple storage hard drive | Vista hardware & devices | |||
| Crashed hard drive...copied hard drive but can't access User area | Vista General | |||
| Transferring files from Slave XP hard drive to new Vista Hard drive - primary | Vista installation & setup | |||
