| | registry problem iam having trouble with my registry and all of the restore things ive retried havent worked. -systom restore - eRecovery management -registry mechanic i have found the corrupt registry but it wont let me delete them. diagnosis- file does not exist ok well i need help.... think of something and post |
| | Re: registry problem 32 bit or 64 bit Operating system? Which corrupt registry keys are you trying to get rid of? CCleaner is a free system cleaning tool that has a registry cleaner in it. You could also try Wise Registry Cleaner (free) or a trial version of Tuneup Utilities 2007. "richard" <richard@xxxxxx> wrote in message news:4885C2E7-A42F-4033-B41C-62B86104EA9D@xxxxxx Quote: > iam having trouble with my registry and all of the restore things ive > retried > havent worked. > > -systom restore > - eRecovery management > -registry mechanic > > i have found the corrupt registry but it wont let me delete them. > > diagnosis- file does not exist > > ok well i need help.... think of something and post |
| | Re: registry problem 32 bit, iam tring to get rid of registry that has no values, it wont let me delete them it says access failed example HIKEY_CLASSES_ROOT\Installer\Products\0e23e40Cg14oD434FA9b96967D309AFE\SourceList HIKEY_CLASSES_ROOT\VirtualStore\MACHINE\SOFTWARE\Microsfot\Windows\CurrentVersion\explorer\volumecaches\Active Setup Temp Folders those are 2 out of 144 problems i got wont let me delete, they have no value "Dave" wrote: Quote: > 32 bit or 64 bit Operating system? > Which corrupt registry keys are you trying to get rid of? > > CCleaner is a free system cleaning tool that has a registry cleaner in it. > You could also try Wise Registry Cleaner (free) or a trial version of Tuneup > Utilities 2007. > > "richard" <richard@xxxxxx> wrote in message > news:4885C2E7-A42F-4033-B41C-62B86104EA9D@xxxxxx Quote: > > iam having trouble with my registry and all of the restore things ive > > retried > > havent worked. > > > > -systom restore > > - eRecovery management > > -registry mechanic > > > > i have found the corrupt registry but it wont let me delete them. > > > > diagnosis- file does not exist > > > > ok well i need help.... think of something and post > |
| | Re: registry problem That's not really enough imformation for anyone to help you, but it sounds like the error is probably relating to a COM listing in HKEY_CLASSES_ROOT. A listing there may be pointing to a "COM server" file that's not present. That's not "corruption" in the Registry, though. Usually it means that you deleted the files of a software program when you should have gone through Add/Remove Programs to get rid of it. Since it wasn't properly uninstalled (or if it's crapware it may not have allowed uninstall) its Registry entries never got removed. So the question becomes: Which is the error - the invalid Registry entry or the missing file? If something needs the file then you'll need to find a replacement copy and leave the Registry alone. If you intended to get rid of that file but didn't properly uninstall, then the entry in HKCR is an "orphan" that can be deleted but will do no harm if left there. Quote: > iam having trouble with my registry and all of the restore things ive Quote: > havent worked. > > -systom restore > - eRecovery management > -registry mechanic > > i have found the corrupt registry but it wont let me delete them. > > diagnosis- file does not exist > > ok well i need help.... think of something and post |
| Registry Problem | System Security | |||
| Registry Problem! | Vista General | |||
| Registry problem | General Discussion | |||
| Registry problem | Vista General | |||
