Vista - Problem
Old 12-09-2007   #1 (permalink)
Nick
Problem
someone got on my laptop and messed with some of the appearance options. i
fixed all except they made my minimize, maximize, and close buttons on
folders and i was wondering how to get them back to their normal size
Old 12-09-2007   #2 (permalink)
Don Varnau
Re: Problem
To change the size of these buttons...
Right-click desktop> Personalize> Window color and appearance> Advanced>
Item: Caption buttons.
Don
[MS MVP- IE]
"Nick" <Nick@xxxxxx> wrote in message
news0E9EBAA-70F1-49B7-B482-13C568935D66@xxxxxx
Old 12-09-2007   #3 (permalink)
Re: Problem
Quote  Quote: Originally Posted by Nick View Post
Hi Nick,
Method Two in this tutorial will show you how to reset the folder view settings.
Windows Explorer Folder View settings
This tutorial will show you how to change them for all the same folder types.
Windows Explorer - Folder Type Templates
This will show you another method to changing the default open window size of a shortcut incase they changed this for you to.
Shortcut Default Open Window Size
Hope this helps you,
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
