Vista - Can I change from 32-bit to 64-bit Vista in my 64-bit machine?
Old 12-09-2007   #1 (permalink)
SRGroman
My 64-bit system came with Home Premium 32-bit installed. Don't I want to
use a 64-bit Vista? How do I upgrade from 32- to 64-bit versions? (I also
purchased Ultimate speparately -- would those disks be useful in making this
transfer?)
Old 12-09-2007   #2 (permalink)
Andre Da Costa[ActiveWin]
Re: Can I change from 32-bit to 64-bit Vista in my 64-bit machine?
You have to do a clean installation for Vista x64, even if you already have
Vista 32 bit installed. As for the disk, you will have order the 64 Bit
Vista Home Premium DVD separately:
Order Alternate media:
Learn more here:
http://www.microsoft.com/windowsvist...a/default.mspx
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"SRGroman" <SRGroman@xxxxxx> wrote in message
news:76052368-7696-428D-8391-6A0B42F3324D@xxxxxx
> also
> this
> transfer?)
Old 12-09-2007   #3 (permalink)
Ken Blake, MVP
On Sun, 9 Dec 2007 13:28:01 -0800, SRGroman
<SRGroman@xxxxxx> wrote:
> use a 64-bit Vista?
Probably not. Until you have 64-bit applications to run (and there are
very few yet), there is essentially no advantage.
You can't It requires a clean installation.
Quote:
> (I also
> transfer?)
Ken Blake, Microsoft MVP Windows - Shell/User
Please Reply to the Newsgroup
Old 12-09-2007   #4 (permalink)
Also take a look at this article by Kris Kenney [MVP] about Windows Vista 32
Bit vs 64 Bit: Whic one is right for you:
http://www.windows-now.com/blogs/kmk...t-for-you.aspx
Andre
> also
> this
> transfer?)
Old 09-21-2009   #5 (permalink)
basam shain
change windows vista home premium
dear
i want change from 32-bit to 64-bit first
second i need multilingua
i need if available to change help and suport to arabic or english in the same time so
best regards
thunks
bassamchahine
Posted as a reply to:
transfer?)
EggHeadCafe - Software Developer Portal of Choice
WCF Workflow Services Using External Data Exchange
http://www.eggheadcafe.com/tutorials...vices-usi.aspx
Old 09-21-2009   #6 (permalink)
Malke
Re: change windows vista home premium
wrote:
Quote:
> dear
> same time so best regards
Purchase Vista Ultimate 64-bits and do a clean install. You will be able to
add languages then.
How do I get additional language files? (watch the line wrap or use the
TinyURL):
http://windowshelp.microsoft.com/Win...help/35a1b021-
d96c-49a5-8d8f-5e9d64ab5ecc1033.mspx#E3
http://tinyurl.com/lnqmkf
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
http://www.elephantboycomputers.com/#FAQ
Old 09-21-2009   #7 (permalink)
basam shain
changefrom32-bit to 64-bit if available
dear basam
so what
dear
best regards
thunks
bassamchahine
Can't Ping vista machine after IP subnet change Network & Sharing
Can you change the computer name of the Host machine? Virtual Server
Remove one Vista on two Vista machine or change system partition? Vista installation & setup
Vista machine cannot change domain password Vista account administration
Removed Functionality - Change a password for a domain account from a workgroup machine. Vista account administration
