annoying process running in background
  1. #1
    T5 Guest
    I have an annoying process running in the background but i just cannot find
    out what it is. I can't locate it in task manager, it is not my antivirus I
    have just checked my processes and all I have is system idle running 79%
    cpu, so what could it be, it is driving me mad.
  2. #2
    Bob T. Guest
    Re: annoying process running in background
    If system idle process % goes down, another process may rise, that should
    tell you the process you're looking for.
    "T5" <noanswer@hotmail.com> wrote in message
    news:FB83F59C-B1D2-48FC-900F-496960D4E481@microsoft.com...
  3. #3
    Rick Rogers Guest
    This works in Vista, and should help you identify what's going on:
    Process Explorer by Sysinternals:
    http://www.sysinternals.com/Processe...Utilities.html
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Windows help - www.rickrogers.org
annoying process running in background problems?
running kompozer gives annoying warning charles cashion Vista General 2 12 Feb 2010
can i launch a process in the background? Xah Lee PowerShell 2 04 Aug 2009
Running in background Min Live Mail 5 12 May 2009
Media Player won't open, not running as process in background MK Vista General 1 20 Jan 2008
Meda Player process starting in background - can't play videos Sean Anderson Vista music pictures video 0 29 Oct 2007
