Vista - Ready Boost Cache Problems
Old 12-10-2007   #1 (permalink)
David H
Ok.... i have read all that I can find on this website and others. When I
put in my SD Card, it gives me the option to speed up my syatem. When I try,
it sayd there is a cache on another drive and to remove that one first. i do
not have anything else plugged into the computer. i may have set up my thumb
drive for Ready boost, I cant remember. When I try and put it in, it also
says there is a cache on another drive. Is there anyway to Reset Readyboost
to get rid of the other drive etc...?
Old 12-10-2007   #2 (permalink)
Quaoar
Re: Ready Boost Cache Problems
I suggest that you do not bother with Ready Boost: very few, if any,
computers will materially benefit from Ready Boost, and the probability
of errors is magnified versus the native Vista.
Q
Old 12-11-2007   #3 (permalink)
gls858
Ready Boost is a waste of time. The only time it seems to help is if you
have the minimum required RAM. You're much better off buying more RAM.
gls858
Old 12-11-2007   #4 (permalink)
David H
Thanks guys. I have 3 gigs of ram anyway.... wont see much diff anyway...
Too bad Readyboost isn't more user friendly...hehe.. Oh well.. cya..
dave
> gls858
NV Cache v Ready Boost Vista performance & maintenance
ready boost General Discussion
ready boost cache Vista hardware & devices
Disappearing ready boost cache space. Vista hardware & devices
Is Ready Boost My answer to performance problems Vista General
