| Guest | Problem at startup .NET framework When windows starts up there is a critical message box every time I start up saying that the .NET framework has a problem resolving a date. There is a Continue or a Quit button and either one works fine with no further problems. What's causing it? can I disable or uninstall anything that will stop it?, can I tell it to ignore the problem each time? What is .NET Framework? do I need it? is that enough questions? |
| Guest | RE: Problem at startup .NET framework "Michelle" wrote: Quote: > When windows starts up there is a critical message box every time I start up > saying that the .NET framework has a problem resolving a date. > > There is a Continue or a Quit button and either one works fine with no > further problems. > > What's causing it? can I disable or uninstall anything that will stop it?, > can I tell it to ignore the problem each time? > > What is .NET Framework? do I need it? is that enough questions? > The libraries don't run by themselves. There must be a problem with a program that is set to startup when the machine starts up. Think about applications that were recently installed and start there by uninstalling. Quote: > |
| .NET Framework 3.5 SP1 install problem ---- Please Help | Vista installation & setup | |||
| .Net framework problem | Windows Updates | |||
| can't update .NET Framework 3.5 Service Pack 1 and .NET Framework 3.5(KB951847 | Windows Updates | |||
| Microsoft .net framework problem | General Discussion | |||
| Problems at startup (.NET framework & programs blocked) | Vista General | |||
