Vista - How to remove my system restore point in vista.
Old 12-12-2007   #1 (permalink)
Randy
what I mean is to remove one of the system restore points that unwanted, I
just want to keep my own created restore point.
So, How ??
Old 12-12-2007   #2 (permalink)
Spirit
Re: How to remove my system restore point in vista.
http://www.bleepingcomputer.com/tuto...torial143.html
"Randy" <Randy@xxxxxx> wrote in message
news:28CA482E-39A3-4EDD-9512-712F27A9CB64@xxxxxx
> So, How ??
Old 12-12-2007   #3 (permalink)
mikeyhsd
you can use System Cleanup to remove all but the last restore point.
then create your own, then use Clean up again.
mikeyhsd@xxxxxx
"Randy" <Randy@xxxxxx> wrote in message news:28CA482E-39A3-4EDD-9512-712F27A9CB64@xxxxxx
So, How ??
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore error (create restore point), event ID: 8193 Vista General
Couldn't create a system restore point in Vista General Discussion
System restore hasn't held a restore point since I installed Vista Vista General
Hide Vista partition(s) from Windows XP - Fix for System Restore Point Corruption! Vista General
