| | Hibernation problems I'm running Windows Vista Ultimate 32-bit, and am having a problem with hibernation. I've installed Virtual PC 2007, and since then I cannot put my computer into hibernation. My system doesn't shut down, it only locks. When I had this problem before, System Restore helped, unfortunately, this time no restore point is available. When I uninstalled the program, it didn't help. I've also tried cleaning the registry (Tweak Now Reg Cleaner Pro), but without any effect. Now I'm really stuck... Is there any way to fix this problem? Beyond that, is there any way Virtual PC will work with Vista and hibernation? Thanks in advanced for your time and help! Emil |
| | Re: Hibernation problems I have been using Virtual PC 2007 for many months on Home Premium and I have had no problems hibernating. A few days ago I did an anytime upgrade to Ultimate which required a fresh install. I have been running Virtual PC 2007 on this new install without any problems hibernating. I can't put my computer to sleep as my computer will always crash shortly after waking up. But that has always been the case with my computer since I bought it about 3 years ago. I think its a hardware problem with my Radeon 9600 Pro video card. "Emil Lulic" <emill@xxxxxx> wrote in message news:9243D979-5D4A-4895-8962-89B523D895B3@xxxxxx Quote: > I'm running Windows Vista Ultimate 32-bit, and am having a problem with > hibernation. I've installed Virtual PC 2007, and since then I cannot put > my computer into hibernation. My system doesn't shut down, it only locks. > When I had this problem before, System Restore helped, unfortunately, this > time no restore point is available. When I uninstalled the program, it > didn't help. I've also tried cleaning the registry (Tweak Now Reg Cleaner > Pro), but without any effect. > Now I'm really stuck... Is there any way to fix this problem? Beyond that, > is there any way Virtual PC will work with Vista and hibernation? > > Thanks in advanced for your time and help! > > Emil |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Hibernation problems I have been using Virtual PC 2007 for many months on Home Premium and I have had no problems hibernating. A few days ago I did an anytime upgrade to Ultimate which required a fresh install. I have been running Virtual PC 2007 on this new install without any problems hibernating. I can't put my computer to sleep as my computer will always crash shortly after waking up. But that has always been the case with my computer since I bought it about 3 years ago. I think its a hardware problem with my Radeon 9600 Pro video card. You might try uninstalling your ATI video drivers in Device Manager, then reinstall them doing a Custom install and not installing the Catalyst Control Center (CCC). See here for the latest drivers. v7.11 AMD GAME! Drivers and Utilities Shawn |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Hibernation problems I'm running Windows Vista Ultimate 32-bit, and am having a problem with hibernation. I've installed Virtual PC 2007, and since then I cannot put my computer into hibernation. My system doesn't shut down, it only locks. When I had this problem before, System Restore helped, unfortunately, this time no restore point is available. When I uninstalled the program, it didn't help. I've also tried cleaning the registry (Tweak Now Reg Cleaner Pro), but without any effect. Now I'm really stuck... Is there any way to fix this problem? Beyond that, is there any way Virtual PC will work with Vista and hibernation? Thanks in advanced for your time and help! Emil You might look through here to see if it may help you. http://www.vistax64.com/tutorials/63...tml#post317574 and http://www.vistax64.com/tutorials/63...-problems.html Shawn |
| | Re: Hibernation problems Please see the following article, offers some helpful workarounds for problems associated with Sleep and Standby on Windows XP and Vista: Fixes for Windows standby and sleep problems http://www.cnet.com/8301-13880_1-982...?tag=nefd.only -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "Emil Lulic" <emill@xxxxxx> wrote in message news:9243D979-5D4A-4895-8962-89B523D895B3@xxxxxx Quote: > I'm running Windows Vista Ultimate 32-bit, and am having a problem with > hibernation. I've installed Virtual PC 2007, and since then I cannot put > my computer into hibernation. My system doesn't shut down, it only locks. > When I had this problem before, System Restore helped, unfortunately, this > time no restore point is available. When I uninstalled the program, it > didn't help. I've also tried cleaning the registry (Tweak Now Reg Cleaner > Pro), but without any effect. > Now I'm really stuck... Is there any way to fix this problem? Beyond that, > is there any way Virtual PC will work with Vista and hibernation? > > Thanks in advanced for your time and help! > > Emil |
| | #6 (permalink) |
| | Re: Hibernation problems Its not a driver problem as this has occurred over the last 3 years or so with many versions of device drivers (from ATI), and also with Windows XP or Vista. I will try to install a PCI video card I have, but I will also have to install Windows XP to try it out as its a ATI 7000 LE card and it doesn't have Vista drivers for it (sleep isn't available under vista). Then I will know if it truly is my video card that is faulty. The only other thing it could be is my ASUS P4P8X mother board, or one of the components built into it. "brink" <brink.31qz25@xxxxxx-mx.forums.net> wrote in message news:brink.31qz25@xxxxxx-mx.forums.net... Quote: > > Gary Mount;547351 Wrote: Quote: >> I have been using Virtual PC 2007 for many months on Home Premium and I >> have >> had no problems hibernating. >> A few days ago I did an anytime upgrade to Ultimate which required a >> fresh >> install. I have been running Virtual PC 2007 on this new install >> without any >> problems hibernating. >> I can't put my computer to sleep as my computer will always crash >> shortly >> after waking up. But that has always been the case with my computer >> since I >> bought it about 3 years ago. I think its a hardware problem with my >> Radeon >> 9600 Pro video card. >> > Hi Gary, > > You might try uninstalling your ATI video drivers in Device Manager, > then reinstall them doing a Custom install and not installing the > Catalyst Control Center (CCC). > > See here for the latest drivers. v7.11 > > 'AMD GAME! Drivers and Utilities' > (http://game.amd.com/us-en/drivers_catalyst.aspx) > > Shawn > > > -- > brink > > *There are no dumb questions, just the people that do not ask them.* > WWW.VISTAX64.COM (\"HTTP://WWW.VISTAX64.COM\") > *Please post feedback to help others.* |
| | #7 (permalink) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Hibernation problems Its not a driver problem as this has occurred over the last 3 years or so with many versions of device drivers (from ATI), and also with Windows XP or Vista. I will try to install a PCI video card I have, but I will also have to install Windows XP to try it out as its a ATI 7000 LE card and it doesn't have Vista drivers for it (sleep isn't available under vista). Then I will know if it truly is my video card that is faulty. The only other thing it could be is my ASUS P4P8X mother board, or one of the components built into it. You should also look through here to see if it may help you to. Powercfg & sleep problems and Powercfg & sleep problems Shawn |
| Vista Hibernation Problems? | General Discussion | |||
| Major problems after hibernation | Vista General | |||
| Hibernation and shutdown problems... | Vista performance & maintenance | |||
| Auto-sleep and hibernation problems | Vista General | |||
| Serious sleep and hibernation problems | Vista General | |||
