| | Volume Shadow Copy (VSS) - System Restore won't start Hello everyone. I'll try to be short and to the point. Today on the 16th-Dec I've found out that my "Control Panel" is having problems and icons won't appear at all. I decided to do a system restore and that is where my problem lies. Two days ago, on the 14th-Dec, I've tampered with my registry by using a "registry cleaner". It seems that other than my Control Panel another couple of programs were not working because of this. Luckily the registry-cleaner program kept backups of the registry entries replaced so I reinserted them. The programs worked correctly after that but the "Control Panel" is still having the issue of disappearing icons. What's worse is that before, or after the re-insertion of the backed-up registry files "system restore" would not work. I have checked with the "Event viewer" and it produces two or three errors which do not have an ID in Technet so I cannot find more about them. One of them (luckily the one appearing more often) does. http://technet2.microsoft.com/window....mspx?mfr=true From "Services" the VSS service fails to start and whenever I try to start it or use the "vssadmin" command from the command prompt I received the following error: "Error: Unexpected failure: The system cannot find the file specified." Any help will be greately appreciated. -Nick |
| | Re: Volume Shadow Copy (VSS) - System Restore won't start Hi. I have just solved my problem with system restore. I found That the "Volume Shadow Contol" Services was on Auto which was good but there is another Service called "Microsoft Shadow copy Provider" which had been disabled. I put this on Auto and started it and was able to start using System Restore. Hope this helps Dave |
| The Volume Shadow Copy service used by System Restore is not working. - help! | Vista General | |||
| System Restore Points without shadow copy - there has got to be a way!! | Vista file management | |||
| System Restore Points without shadow copy - there has got to be a way!! | Vista performance & maintenance | |||
| System Restore Points without shadow copy - there has got to be a way!! | Vista General | |||
| Backup, Restore, Volume Shadow Copy Problems | Vista performance & maintenance | |||
