Vista - System Restore Failure
Old 12-18-2007   #1 (permalink)
andreamc1
I have a Dell Desktop and all of a sudden my Office 2007 Word program starts
giving me problems. Its starts out with not allowing me to use my mouse on a
document. Second, it no longer has the numerous templates to select from in
the menu that I use all the time. Now it wont even let me download a document
from my email account in order to view it.
Action: I tried all the updates and nothing worked. I resorted to
uninstalling and reinstalling office entirely even though Word was the only
application that was not functioning properly. That did not solve the
problem.
Second, I tried to restore twice with two different points and was
unsuccessful.
Could it be something with my Norton Antivirus??
The only thing now to do is either try another point like when I bought that
computer which was about 10 months ago, and/or reinstall Vista.
What is the best plan of attack?????
Old 12-18-2007   #2 (permalink)
Mick Murphy
RE: System Restore Failure
Disable norton and retry download of word document.
> problem.
> unsuccessful.
Old 12-18-2007   #3 (permalink)
andreamc1
Still didnt work. What else would you suggest?
> > problem.
> > unsuccessful.
Vista System Restore failure Vista performance & maintenance
System restore failure in Vist Home Premium Vista performance & maintenance
startup failure & system restore 'WINRE' query Vista performance & maintenance
system restore failure Vista performance & maintenance
System Restore failure Vista security
