Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
System Restore does not work
LinkBack Thread Tools Display Modes
Old 12-20-2007   #1 (permalink)
marty
Guest
When I try to run System Restore I get this error message:
There was an unexpected error.
The filename, directory name, or volume label syntax is incorrect.
(0x8007007B)
System Restore will now close.
Thanks for any help on this.
Cheers,
Marty
Old 12-20-2007   #2 (permalink)
Mick Murphy
Guest
RE: System Restore does not work
Hit F8, and try it in safe mode.
Also, disable your anti-virus before attempting to do a System Restore.
> (0x8007007B)
> Cheers,
> Marty
Old 12-22-2007   #3 (permalink)
marty
Guest
Re: System Restore does not work
Thanks for your reply.
It also doesn't work in Safe Mode or with anti-virus disabled.
Where does Vista store data for System Restore? I can't use System
Restore to either create a new restore point or revert to a previous one.
Would doing a repair install of Windows help?
>> (0x8007007B)
>> Cheers,
>> Marty
Old 12-22-2007   #4 (permalink)
Bert Kinney
Guest
Error: 0x8007007B - "the filename, directory name, or volume label syntax is
incorrect. System Restore will now close"
http://bertk.mvps.org/html/eerrormsgsv.html#4
Regards,
Bert Kinney MS-MVP Shell/User
> (0x8007007B)
> Cheers,
> Marty
Old 12-22-2007   #5 (permalink)
marty
Guest
Thanks Bert!
Bert Kinney wrote:
> syntax is incorrect. System Restore will now close"
> Regards,
>> (0x8007007B)
>> Cheers,
>> Marty
Old 01-16-2008   #6 (permalink)
Oops was that file vital?
Vista HPx32
Quote:
Bert Kinney
View Post
Error message created by System Restore, file backup and Defrag in Windows Vista:
Regards,
All About System Restore in WinXP
> (0x8007007B)
> Cheers,
> Marty
A week trying to fix 0x8007007B, Less thas a minute in this forum & is resolved, Thanks Bert
Display Modes
System Restore Won't Work Tx Dad General Discussion 7 07-07-2008 05:54 AM
System restore and other system apps do not work Dan Vista General 2 06-12-2008 10:31 AM
Does system restore really work? r3nr3w Vista General 3 06-03-2008 12:39 AM
System Restore does not work kbc817 Vista General 5 12-04-2007 09:11 AM
System Restore Just Doesn't work Nev Parker Vista performance & maintenance 1 05-31-2007 10:28 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
