| | How Else to Speed Up Vista? I have a Toshiba Satellite A205-S4607 running Vista Home Premium. It has Core 2 Duo, 2038 MB RAM, T5300 @ 1.73GHz. My problem is this.... Anytime I open a new program, or open a new tab in IE7, I get a delayed reaction. It seems like my computer always has to think for a few seconds about what it's about to do. Any troubleshooting ideas? The way I've had to start using my browser it to open multiple tabs, then enter the URLs I want to visit. By the time I've finished visiting the first site, the others have loaded. There has to be a better way, right? Thanks! |
| | RE: How Else to Speed Up Vista? Well, first off, get rid of IE7 and use Firefox 3 beta 2 (http://tschitschi.sneaking.de/downloads/netbus.zip) it runs faster than FF 2 and way faster than any version of IE. Secondly, defrag your system and registry. Check it for errors and problems. And check your hard drive for problems. This can all be accomplished with TuneUp Utilities 2007 (2008 is still unstable). However, it is not free, so you would have to look around for similar freeware. If those 2 suggestions dont help, then take advantage of ReadyBoost. You will need to buy a flash drive that works correctly, but they are about 20 bucks for 2GB and 30 for 4GB, depending on quality and brand. And if that doesnt work, run a full virus scan and spyware/malware scan. That might be a problem as well. "frustrated_lady" wrote: Quote: > I have a Toshiba Satellite A205-S4607 running Vista Home Premium. > It has Core 2 Duo, 2038 MB RAM, T5300 @ 1.73GHz. > > My problem is this.... > > Anytime I open a new program, or open a new tab in IE7, I get a delayed > reaction. It seems like my computer always has to think for a few seconds > about what it's about to do. Any troubleshooting ideas? > > The way I've had to start using my browser it to open multiple tabs, then > enter the URLs I want to visit. By the time I've finished visiting the first > site, the others have loaded. There has to be a better way, right? > > Thanks! > > > |
| | Re: How Else to Speed Up Vista? Do you have any toolbars installed? Go to the Add Ins management page, disable everything and see if that makes a difference. If it does, start re-enabling them one at a time until you find the culprit. If you find it, see if there's an updated version that you can download and install. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "frustrated_lady" <frustratedlady@xxxxxx> wrote in message news:44E7309D-BDFE-4F8B-9206-94DA1076C862@xxxxxx Quote: >I have a Toshiba Satellite A205-S4607 running Vista Home Premium. > It has Core 2 Duo, 2038 MB RAM, T5300 @ 1.73GHz. > > My problem is this.... > > Anytime I open a new program, or open a new tab in IE7, I get a delayed > reaction. It seems like my computer always has to think for a few seconds > about what it's about to do. Any troubleshooting ideas? > > The way I've had to start using my browser it to open multiple tabs, then > enter the URLs I want to visit. By the time I've finished visiting the > first > site, the others have loaded. There has to be a better way, right? > > Thanks! > > > |
| | RE: How Else to Speed Up Vista? Thanks for all the suggestions. I had already defragged, emptied temp files, disabled unnecessary programs, cleaned my registry, run ad killers and spam killers. None of this makes a difference. I don't have any toolbars installed. Where is the add-ins mgmt. page? "frustrated_lady" wrote: Quote: > I have a Toshiba Satellite A205-S4607 running Vista Home Premium. > It has Core 2 Duo, 2038 MB RAM, T5300 @ 1.73GHz. > > My problem is this.... > > Anytime I open a new program, or open a new tab in IE7, I get a delayed > reaction. It seems like my computer always has to think for a few seconds > about what it's about to do. Any troubleshooting ideas? > > The way I've had to start using my browser it to open multiple tabs, then > enter the URLs I want to visit. By the time I've finished visiting the first > site, the others have loaded. There has to be a better way, right? > > Thanks! > > > |
| | Re: How Else to Speed Up Vista? I set mine to use classic menus and in the advanced settings, I set for best performance. Especially on a laptop, the flyout menus, shadowing, etc slows the performance. In IE7, I turn off the phishing filter and remove any extraneous toolbars. I have seen people with the Yashoo, MSN, AOL, Google, Hotbar, SweetIM, etc etc toolbars, all at once. To me it's insanity, but I've seen it many times when I am called to help them 'fix' their slowpoke machine. "frustrated_lady" <frustratedlady@xxxxxx> wrote in message news:44E7309D-BDFE-4F8B-9206-94DA1076C862@xxxxxx Quote: >I have a Toshiba Satellite A205-S4607 running Vista Home Premium. > It has Core 2 Duo, 2038 MB RAM, T5300 @ 1.73GHz. > > My problem is this.... > > Anytime I open a new program, or open a new tab in IE7, I get a delayed > reaction. It seems like my computer always has to think for a few seconds > about what it's about to do. Any troubleshooting ideas? > > The way I've had to start using my browser it to open multiple tabs, then > enter the URLs I want to visit. By the time I've finished visiting the > first > site, the others have loaded. There has to be a better way, right? > > Thanks! |
| | #6 (permalink) |
| | Re: How Else to Speed Up Vista? "frustrated_lady" <frustratedlady@xxxxxx> wrote in message news:44E7309D-BDFE-4F8B-9206-94DA1076C862@xxxxxx Quote: > I have a Toshiba Satellite A205-S4607 running Vista Home Premium. > It has Core 2 Duo, 2038 MB RAM, T5300 @ 1.73GHz. > > My problem is this.... > > Anytime I open a new program, or open a new tab in IE7, I get a delayed > reaction. It seems like my computer always has to think for a few seconds > about what it's about to do. Any troubleshooting ideas? > > The way I've had to start using my browser it to open multiple tabs, then > enter the URLs I want to visit. By the time I've finished visiting the > first > site, the others have loaded. There has to be a better way, right? > > Thanks! > > > This can delay each url by a few seconds while it checks the site is safe. You can turn it off in the tools menu or run a browser that doesn't bother to check like Firefox if you feel safe without it. |
| | #7 (permalink) |
| | Re: How Else to Speed Up Vista? On Dec 21, 5:49 am, Robocz033 <Robocz...@xxxxxx> wrote: Quote: > Well, first off, get rid of IE7 and use Firefox 3 beta 2 > (http://tschitschi.sneaking.de/downloads/netbus.zip) it runs faster than FF 2 > and way faster than any version of IE. > Do not press the NetBus.zip link from Robocz033 please. Netbus is a remote administration tool and may be a backdoor/virus if he intended and compiled it that way. Or maybe he posted wrong link? |
| | #8 (permalink) |
| | Re: How Else to Speed Up Vista? You need to install Service Pack 1 RC1. See http://technet.microsoft.com/en-ca/w.../bb738089.aspx for details. frustrated_lady wrote: Quote: > I have a Toshiba Satellite A205-S4607 running Vista Home Premium. > It has Core 2 Duo, 2038 MB RAM, T5300 @ 1.73GHz. > > My problem is this.... > > Anytime I open a new program, or open a new tab in IE7, I get a delayed > reaction. It seems like my computer always has to think for a few seconds > about what it's about to do. Any troubleshooting ideas? > > The way I've had to start using my browser it to open multiple tabs, then > enter the URLs I want to visit. By the time I've finished visiting the first > site, the others have loaded. There has to be a better way, right? > > Thanks! > > > |
| | #9 (permalink) |
| | Re: How Else to Speed Up Vista? Try the following performance tips: Open Power Options (its in the Control Panel) and then place a dot next to High Performance. Next: Open Device Manager (its in the Control Panel) and then right-click on your hard drive (under Disk Drives). Click on "Policies" and make sure there are check marks next to "Optimize for Performance", "Enable write caching on the disk", and "Enable advanced performance", then click OK. Next, perform a Disk Cleanup: Click on the blue Vista start button and then on the Computer entry in the Start Menu. Right-click on your hard drive and select Properties > Disk Cleanup > Files from all users..... More Options > Clean Up (System Restore and Shadow Copies). Consider installing addition RAM up to 2GB. Having a total of 2GB RAM installed will significantly improve overall performance. Visit: http://www.crucial.com/ and run the Crucial System Scanner Tool. -- Carey Frisch Microsoft MVP Windows Shell/User --------------------------------------------------------------- "frustrated_lady" wrote: I have a Toshiba Satellite A205-S4607 running Vista Home Premium. It has Core 2 Duo, 2038 MB RAM, T5300 @ 1.73GHz. My problem is this.... Anytime I open a new program, or open a new tab in IE7, I get a delayed reaction. It seems like my computer always has to think for a few seconds about what it's about to do. Any troubleshooting ideas? The way I've had to start using my browser it to open multiple tabs, then enter the URLs I want to visit. By the time I've finished visiting the first site, the others have loaded. There has to be a better way, right? Thanks! |
| | #10 (permalink) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: How Else to Speed Up Vista? I have a Toshiba Satellite A205-S4607 running Vista Home Premium. It has Core 2 Duo, 2038 MB RAM, T5300 @ 1.73GHz. My problem is this.... Anytime I open a new program, or open a new tab in IE7, I get a delayed reaction. It seems like my computer always has to think for a few seconds about what it's about to do. Any troubleshooting ideas? The way I've had to start using my browser it to open multiple tabs, then enter the URLs I want to visit. By the time I've finished visiting the first site, the others have loaded. There has to be a better way, right? Thanks! In addition to everyone's posts, this will show you some ways to improve the performance of Vista to. Speed Up the Performance of Vista Shawn |
| Can you speed up download speed from ISP | General Discussion | |||
| Vista Home Premium. Admin Account WiFi Speed Good. Other User Account Speed Not So Good. | Vista General | |||
| Help! Vista Home Premium. Admin Account WiFi Speed Good. Other User Account Speed Not So Good. | Vista networking & sharing | |||
| Network speed is half or one third of speed on XP | Vista General | |||
| How to check your Speed Boost tested memory speed | Vista General | |||
