| | Vista - DVD problem solved |
| 12-21-2007 | #1 |
| | DVD problem solved I too have had problems writing and reading data DVDs. After burning files to a DVD explorer would not list the files even though Vista was showing how much free space I had on the disk. At times the drive would simply stop writing and another custom coaster was created. In an effort to solve this problem I upgraded the firmware but it still did not work consistantly. I then came across some information that indicated the DVD must be connected to the motherboard using an 80 conductor cable. Sure enough after changing out the existing 40 conductor cable to an 80 the drive works fine. This setup worked fine on XP but for some reason had problems with vista. Hope this can help others who are having similar problems writing to and reading from DVDs. Drive is an ATAPI DVD DD 2X16X4X16 ATA device Upgraded the firmware to G7Z9 (this may not be the latest but it works) |
| My System Specs |
| Similar Threads for: DVD problem solved | ||||
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Spooler problem solved | Vista print fax & scan | |||
| Problem solved | Vista mail | |||
| Problem with 3180 solved | Vista print fax & scan | |||
| Access problem solved! | Vista print fax & scan | |||
