Vista - I have a problem...
Old 12-22-2007   #1 (permalink)
vista ultimate
I have a problem...
I installed vista ultimate on my laptop. I have had no problems with anything but my media player. About half of the time it locks up and I have to totally shut down to do anything. I am still pretty new to computer knowledge and I didnt know if there was a simple fix or what. Could someone help? Right now I am running WMP 11.
Old 12-22-2007   #2 (permalink)
Windows Vista x64 Ultimate
Re: I have a problem...
Quote  Quote: Originally Posted by huntersplinter View Post
Try running Windows Update.
Also, the problem may not be WMP 11 itself, but rather the media codec being used. You may also want to download and install updated codecs for your system.
And just for reference, the title of your posts should be indicative of the problem. For example "Windows Media Player 11 freezes" will work alot better than "I have a problem". Giving a descriptive title to your post will help you to get a reply sooner, as generic post titles are more often than not simply ignored.
Old 12-22-2007   #3 (permalink)
vista ultimate
Thank you, I guess its evident I am pretty new at this.
Old 12-23-2007   #4 (permalink)
We all go to start somewhere, right?
Have you tried as I suggested, and checked for Windows Updates or for new codecs?
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
