Vista - Registry problem
Old 12-24-2007   #1 (permalink)
Len Cuff
Registry problem
First of all I have to admit to causing this problem due to some over
zealous editing! I was attempting to re-install a program which kept
on saying it was already installed despite the correct unnstall via
control panel. I had to go through the registry and delete al
references to it and it would seem that I have deleted a key
incorrectly!
When I try to run msconfig I get this message --
"The system could not find the environment option that was entered"
and if I try to go to the secuity centre I get this message --
Windows cannot find %windir%\\system32\\wscui.cpl
Looks like I have deleted some environment variable(s) so does anyone
know how to recover them please?
TIA
cheers,
Len
Old 12-24-2007   #2 (permalink)
Bob Eyster
Re: Registry problem
Restore the backup copy you made before you started editing
Bob Eyster
MS Windows Vista Home Premium
"Len Cuff" <len.cuff@xxxxxx> wrote in message
news:7buum3d99n5poo8kbfg6hle0k4104hjvud@xxxxxx
> incorrectly!
> TIA
> cheers,
> Len
Old 12-24-2007   #3 (permalink)
Len Cuff
On Mon, 24 Dec 2007 08:26:58 -0500, "Bob Eyster"
<reyster1@xxxxxx> wrote:
I would if I could get System Restore to work!!
cheers,
Len
Old 12-24-2007   #4 (permalink)
CB
> cheers,
> Len
Len,
I may be wrong, but I think Bob Eyster was speaking about the registry
backup itself. Did you back up the registry before altering it?
Have a nice day.
C.B.
Old 12-24-2007   #5 (permalink)
uvbogden
You are having some serious install/uninstall problems; you may indeed have a
corrupt registry. Please see these two tutorials for help with
install/uninstall problems and your Repair Vista Options. If these fail to
help, you might need to run a good registry scanner/cleaner.
Unable To Install Latest Version of Program on Vista
Repair Vista Options - Preferred Sequence
http://www.ccleaner.com/
http://wisecleaner.com/download.html
> cheers,
> Len
Old 12-25-2007   #6 (permalink)
Len Cuff
On Mon, 24 Dec 2007 09:24:08 GMT, Len Cuff <len.cuff@xxxxxx>
wrote:
In the end I decided to bite the bullet and clone my boot disk from a
copy I had made a couple of days ago. I think something went seriously
wrong with the registry so this was the easy way to recover it all.
Glad to say it all worked fine and I am now back to a stabel state
again.
Thanks for all the advice and help on this one but I think I deleted
some rather vital registry entires my mistake!
>incorrectly!
>TIA
>cheers,
> Len
cheers,
Len
Old 12-25-2007   #7 (permalink)
bomb#20
> again.
Some time ago I did just what you did and since then I use Erunt to backup
my registry. It's free and you can have it backup daily if you want.
If you play around in the registry it is a must-have prog. :-)
http://www.larshederer.homepage.t-online.de/erunt
Old 12-26-2007   #8 (permalink)
Len Cuff
>> again.
I also have that but I thought it was only for XP? Is it Ok with
Vista? I did have a complete backup made with Genie Backup but it was
a bit older than the disk clone I had made. Maybe I am a bit mad but I
usually make a complete clone of my boot drive once a week using
Acronis 10. It certainly saved me this time!
cheers,
Len
Old 12-26-2007   #9 (permalink)
Vista home premium 64 bit
OK guys, he hased muched up his reqistry file. Now tell him how to recreat it
Registry Problem System Security
Registry Problem! Vista General
Registry problem General Discussion
registry problem Vista General
Registry problem Vista General
