Vista Tutorial - Wireless network adapter card issues w/ Vista
Old 12-24-2007   #1 (permalink)
Terry
Guest
I have a new HP Pavilion 6200CTO PC w/ Broadcom 803.11 wireless card and
Bluetooth that is not recognized by Vista. All updated drivers are loaded and
even had HP replace motherboard and wireless card with no positive results.
PC keeps saying No wireless hardware is installed even though it is in
machine. Has anyone else had this problem and what is fix?
Thanks for any help,
Terry
Old 12-24-2007   #2 (permalink)
Quaoar
Guest
Re: Wireless network adapter card issues w/ Vista
> Terry
Some HP notebooks have a manual wireless switch on the front margin of
the notebook. ??
Q
Old 12-25-2007   #3 (permalink)
Terry
Guest
Yes notebook has manual switch on front and it is on. However, device manager
does not show WLAN driver in network adapter listing. Only Bluetooth and
ethernet controller are listed in manager. HP service says something on
motherboard is not connecting with WLAN card but both have been replaced.
WLAN still not working. wired LAN works fine.
The result of ipconfig/all:
C:\Users\TerryCMajor>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : TerryCMajor-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Bluetooth Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Bluetooth Device (Personal Area
Network)
Physical Address. . . . . . . . . : 00-1A-6B-2E-4C-A2
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-16-36-93-85-5A
Link-local IPv6 Address . . . . . : fe80::d8e1:a8fe:63d5:7ca1%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.11(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, December 25, 2007 5:54:53 PM
Lease Expires . . . . . . . . . . : Tuesday, December 25, 2007 6:54:53 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 184555062
DNS Servers . . . . . . . . . . . : 24.247.24.53
24.247.15.53
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 7:
isatap.{F6443538-DB1D-4C6C-93CB-4C64DBEC8
940}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.0.11%12(Preferred)
24.247.15.53
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 9:
isatap.{61D0D83E-A11D-4C72-8623-4E3FE8C55
8D4}
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
IPv6 Address. . . . . . . . . . . :
2001:0:4136:e388:3055:3cda:3f57:fff4(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::3055:3cda:3f57:fff4%9(Preferred)
Default Gateway . . . . . . . . . : ::
Hope this helps.
Terry
> > Terry
> the notebook. ??
> Q
Vista Supported Wireless USB Adapter / Wireless PCI Card Vista General
WIRELESS network adapter FAILURE on Vista ONLY AFTER SLEEP Vista hardware & devices
Wireless network adapter failure on Vista only after resume from s Vista General
how to turn on wireless network adapter in vista Vista networking & sharing
Wireless USB Network Adapter with Vista Vista General
