| | Excel 2007 Problem with 2008 Calendar When using the fill button for dates in Excel 2007 I encountered this problem: 2/11... 2/18... 2/25... 3/4 (should have been 3/3 as Monday in 2008 is March 3 not March 4). When looking at Microsoft Calendar templates in Excel for 2008 the dates for MArch look correct. Is there a leap year problem in Excel 2007? Ted |
| | Re: Excel 2007 Problem with 2008 Calendar It is probably reading the year for 2/11 as 2007 and not 2008. When I gave 2/11/2008 with display as 2/11, it calculates the correct series fill 3/3 for Monday, March 3. - Chirag PowerShow - View multiple PowerPoint slide shows simultaneously http://officeone.mvps.org/powershow/powershow.html "Ted" <Ted@xxxxxx> wrote in message news 6E9F969-EA4E-4E42-A14B-D687041876AE@xxxxxxQuote: > When using the fill button for dates in Excel 2007 I encountered this > problem: > > 2/11... 2/18... 2/25... 3/4 (should have been 3/3 as Monday in 2008 is > March 3 not March 4). > > When looking at Microsoft Calendar templates in Excel for 2008 the dates > for > MArch look correct. > > Is there a leap year problem in Excel 2007? > Ted |
| | Re: Excel 2007 Problem with 2008 Calendar YOU ARE CORRECT. My goof. Thanks a bunch. -- Ted "Chirag" wrote: Quote: > It is probably reading the year for 2/11 as 2007 and not 2008. When I gave > 2/11/2008 with display as 2/11, it calculates the correct series fill 3/3 > for Monday, March 3. > > - Chirag > > PowerShow - View multiple PowerPoint slide shows simultaneously > http://officeone.mvps.org/powershow/powershow.html > > "Ted" <Ted@xxxxxx> wrote in message > news 6E9F969-EA4E-4E42-A14B-D687041876AE@xxxxxxQuote: > > When using the fill button for dates in Excel 2007 I encountered this > > problem: > > > > 2/11... 2/18... 2/25... 3/4 (should have been 3/3 as Monday in 2008 is > > March 3 not March 4). > > > > When looking at Microsoft Calendar templates in Excel for 2008 the dates > > for > > MArch look correct. > > > > Is there a leap year problem in Excel 2007? > > Ted |
| WLM 2007 (2008) --> WLM 2009: important faults. Therefore, WLM 2009 --> WLM 2007 (2008) | Live Mail | |||
| Excel 2007/ Vista- Problem Duplicating Worksheets Within Same Work | Vista General | |||
| problem in faxing excel 2007 documents | Vista print fax & scan | |||
| Excel 2007 wil not open and Excel 2007 document in Vista? | Vista General | |||
| Outlook 2007 + WM5 sync, strange calendar problem | Vista General | |||
