| | Lotus Approach from Smartsuite 9.8 - need help All the files in the latest Lotus Smartsuite 9.8 run except for Approach. Error messge : "could not find smarticons. Please run install.exe to re-install Lotus. Approach works in Windows XP and SBS 2003. The swarticons are on the hard drive. I even found the *.smi and re-associated them with Lotus Approach. Any suggestions besides re-install Lotus. thanks |
| | Re: Lotus Approach from Smartsuite 9.8 - need help Have you tried running it in compatibility. Check the properties of the executable under > Compatibility (tab). -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "David Sherman" <dshermin@ameritech.net> wrote in message news:kjcs42tharra9m11u38gp2diikh28uv5eh@4ax.com... > All the files in the latest Lotus Smartsuite 9.8 run except for > Approach. Error messge : > "could not find smarticons. Please run install.exe to re-install > Lotus. > > Approach works in Windows XP and SBS 2003. The swarticons are on the > hard drive. > > I even found the *.smi and re-associated them with Lotus Approach. > > Any suggestions besides re-install Lotus. > > thanks > |
| | Re: Lotus Approach from Smartsuite 9.8 - need help yes, I did. >Have you tried running it in compatibility. Check the properties of the >executable under > Compatibility (tab). > >-- >-- >Andre >Windows Connected | http://www.windowsconnected.com >Extended64 | http://www.extended64.com >Blog | http://www.extended64.com/blogs/andre >http://spaces.msn.com/members/adacosta > >"David Sherman" <dshermin@ameritech.net> wrote in message >news:kjcs42tharra9m11u38gp2diikh28uv5eh@4ax.com... >> All the files in the latest Lotus Smartsuite 9.8 run except for >> Approach. Error messge : >> "could not find smarticons. Please run install.exe to re-install >> Lotus. >> >> Approach works in Windows XP and SBS 2003. The swarticons are on the >> hard drive. >> >> I even found the *.smi and re-associated them with Lotus Approach. >> >> Any suggestions besides re-install Lotus. >> >> thanks >> > |
| | Re: Lotus Approach from Smartsuite 9.8 - need help I think this is where IBM Lotus Development, please contact them about Windows Vista support or updates for the application to support Vista. -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "David Sherman" <dshermin@ameritech.net> wrote in message news:vgms42l4pd1hp98dtq2jqfjlnbcunf69mm@4ax.com... > yes, I did. > >>Have you tried running it in compatibility. Check the properties of the >>executable under > Compatibility (tab). >> >>-- >>-- >>Andre >>Windows Connected | http://www.windowsconnected.com >>Extended64 | http://www.extended64.com >>Blog | http://www.extended64.com/blogs/andre >>http://spaces.msn.com/members/adacosta >> >>"David Sherman" <dshermin@ameritech.net> wrote in message >>news:kjcs42tharra9m11u38gp2diikh28uv5eh@4ax.com... >>> All the files in the latest Lotus Smartsuite 9.8 run except for >>> Approach. Error messge : >>> "could not find smarticons. Please run install.exe to re-install >>> Lotus. >>> >>> Approach works in Windows XP and SBS 2003. The swarticons are on the >>> hard drive. >>> >>> I even found the *.smi and re-associated them with Lotus Approach. >>> >>> Any suggestions besides re-install Lotus. >>> >>> thanks >>> >> > |
| | Re: Lotus Approach from Smartsuite 9.8 - need help Contact the manufacture (Corel now I believe) and see what their plans are for Vista in the future. Lotus has always been a bit funny - we have it running on our server as a DTP product and it's no match for Office to be honest. -- Zack Whittaker » ZackNET Enterprises: www.zacknet.co.uk » MSBlog on ResDev: www.msblog.org » Vista Knowledge Base: www.vistabase.co.uk » This mailing is provided "as is" with no warranties, and confers no rights. All opinions expressed are those of myself unless stated so, and not of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared that up! --: Original message follows :-- "Andre Da Costa [Extended64]" <andred25@hotmail.com> wrote in message news:OVoBBBOaGHA.4060@TK2MSFTNGP02.phx.gbl... >I think this is where IBM Lotus Development, please contact them about >Windows Vista support or updates for the application to support Vista. > -- > -- > Andre > Windows Connected | http://www.windowsconnected.com > Extended64 | http://www.extended64.com > Blog | http://www.extended64.com/blogs/andre > http://spaces.msn.com/members/adacosta > > "David Sherman" <dshermin@ameritech.net> wrote in message > news:vgms42l4pd1hp98dtq2jqfjlnbcunf69mm@4ax.com... >> yes, I did. >> >>>Have you tried running it in compatibility. Check the properties of the >>>executable under > Compatibility (tab). >>> >>>-- >>>-- >>>Andre >>>Windows Connected | http://www.windowsconnected.com >>>Extended64 | http://www.extended64.com >>>Blog | http://www.extended64.com/blogs/andre >>>http://spaces.msn.com/members/adacosta >>> >>>"David Sherman" <dshermin@ameritech.net> wrote in message >>>news:kjcs42tharra9m11u38gp2diikh28uv5eh@4ax.com... >>>> All the files in the latest Lotus Smartsuite 9.8 run except for >>>> Approach. Error messge : >>>> "could not find smarticons. Please run install.exe to re-install >>>> Lotus. >>>> >>>> Approach works in Windows XP and SBS 2003. The swarticons are on the >>>> hard drive. >>>> >>>> I even found the *.smi and re-associated them with Lotus Approach. >>>> >>>> Any suggestions besides re-install Lotus. >>>> >>>> thanks >>>> >>> >> > > |
| | #6 (permalink) |
| | Re: Lotus Approach from Smartsuite 9.8 - need help I tend to disagree. Lotus Smartsuite works under SBS 2003 and XP. It should run under Vista unless something in the Vista broke Lotus Approach. On Tue, 25 Apr 2006 20:19:31 -0700, "Andre Da Costa [Extended64]" <andred25@hotmail.com> wrote: >I think this is where IBM Lotus Development, please contact them about >Windows Vista support or updates for the application to support Vista. >-- >-- >Andre >Windows Connected | http://www.windowsconnected.com >Extended64 | http://www.extended64.com >Blog | http://www.extended64.com/blogs/andre >http://spaces.msn.com/members/adacosta > >"David Sherman" <dshermin@ameritech.net> wrote in message >news:vgms42l4pd1hp98dtq2jqfjlnbcunf69mm@4ax.com... >> yes, I did. >> >>>Have you tried running it in compatibility. Check the properties of the >>>executable under > Compatibility (tab). >>> >>>-- >>>-- >>>Andre >>>Windows Connected | http://www.windowsconnected.com >>>Extended64 | http://www.extended64.com >>>Blog | http://www.extended64.com/blogs/andre >>>http://spaces.msn.com/members/adacosta >>> >>>"David Sherman" <dshermin@ameritech.net> wrote in message >>>news:kjcs42tharra9m11u38gp2diikh28uv5eh@4ax.com... >>>> All the files in the latest Lotus Smartsuite 9.8 run except for >>>> Approach. Error messge : >>>> "could not find smarticons. Please run install.exe to re-install >>>> Lotus. >>>> >>>> Approach works in Windows XP and SBS 2003. The swarticons are on the >>>> hard drive. >>>> >>>> I even found the *.smi and re-associated them with Lotus Approach. >>>> >>>> Any suggestions besides re-install Lotus. >>>> >>>> thanks >>>> >>> >> > |
| | #7 (permalink) |
| | Re: Lotus Approach from Smartsuite 9.8 - need help IBM support has no answer. I expect that there will be a new version next year. I agree the Lotus Smartsuite is a dead program with little future. On Wed, 26 Apr 2006 18:39:18 +0100, "Zack Whittaker" <admin@zacknet.co.uk> wrote: >Contact the manufacture (Corel now I believe) and see what their plans are >for Vista in the future. >Lotus has always been a bit funny - we have it running on our server as a >DTP product and it's no match for Office to be honest. > >-- >Zack Whittaker >» ZackNET Enterprises: www.zacknet.co.uk >» MSBlog on ResDev: www.msblog.org >» Vista Knowledge Base: www.vistabase.co.uk >» This mailing is provided "as is" with no warranties, and confers no >rights. All opinions expressed are those of myself unless stated so, and not >of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared >that up! > > --: Original message follows :-- >"Andre Da Costa [Extended64]" <andred25@hotmail.com> wrote in message >news:OVoBBBOaGHA.4060@TK2MSFTNGP02.phx.gbl... >>I think this is where IBM Lotus Development, please contact them about >>Windows Vista support or updates for the application to support Vista. >> -- >> -- >> Andre >> Windows Connected | http://www.windowsconnected.com >> Extended64 | http://www.extended64.com >> Blog | http://www.extended64.com/blogs/andre >> http://spaces.msn.com/members/adacosta >> >> "David Sherman" <dshermin@ameritech.net> wrote in message >> news:vgms42l4pd1hp98dtq2jqfjlnbcunf69mm@4ax.com... >>> yes, I did. >>> >>>>Have you tried running it in compatibility. Check the properties of the >>>>executable under > Compatibility (tab). >>>> >>>>-- >>>>-- >>>>Andre >>>>Windows Connected | http://www.windowsconnected.com >>>>Extended64 | http://www.extended64.com >>>>Blog | http://www.extended64.com/blogs/andre >>>>http://spaces.msn.com/members/adacosta >>>> >>>>"David Sherman" <dshermin@ameritech.net> wrote in message >>>>news:kjcs42tharra9m11u38gp2diikh28uv5eh@4ax.com... >>>>> All the files in the latest Lotus Smartsuite 9.8 run except for >>>>> Approach. Error messge : >>>>> "could not find smarticons. Please run install.exe to re-install >>>>> Lotus. >>>>> >>>>> Approach works in Windows XP and SBS 2003. The swarticons are on the >>>>> hard drive. >>>>> >>>>> I even found the *.smi and re-associated them with Lotus Approach. >>>>> >>>>> Any suggestions besides re-install Lotus. >>>>> >>>>> thanks >>>>> >>>> >>> >> >> > |
| | #8 (permalink) |
| | Re: Lotus Approach from Smartsuite 9.8 - need help You contradicted yourself. ![]() -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "David Sherman" <dshermin@ameritech.net> wrote in message news:mriv42155rltvanpbbm57ri2e66p6a8ufb@4ax.com... >I tend to disagree. Lotus Smartsuite works under SBS 2003 and XP. It > should run under Vista unless something in the Vista broke Lotus > Approach. > > > > > On Tue, 25 Apr 2006 20:19:31 -0700, "Andre Da Costa [Extended64]" > <andred25@hotmail.com> wrote: > >>I think this is where IBM Lotus Development, please contact them about >>Windows Vista support or updates for the application to support Vista. >>-- >>-- >>Andre >>Windows Connected | http://www.windowsconnected.com >>Extended64 | http://www.extended64.com >>Blog | http://www.extended64.com/blogs/andre >>http://spaces.msn.com/members/adacosta >> >>"David Sherman" <dshermin@ameritech.net> wrote in message >>news:vgms42l4pd1hp98dtq2jqfjlnbcunf69mm@4ax.com... >>> yes, I did. >>> >>>>Have you tried running it in compatibility. Check the properties of the >>>>executable under > Compatibility (tab). >>>> >>>>-- >>>>-- >>>>Andre >>>>Windows Connected | http://www.windowsconnected.com >>>>Extended64 | http://www.extended64.com >>>>Blog | http://www.extended64.com/blogs/andre >>>>http://spaces.msn.com/members/adacosta >>>> >>>>"David Sherman" <dshermin@ameritech.net> wrote in message >>>>news:kjcs42tharra9m11u38gp2diikh28uv5eh@4ax.com... >>>>> All the files in the latest Lotus Smartsuite 9.8 run except for >>>>> Approach. Error messge : >>>>> "could not find smarticons. Please run install.exe to re-install >>>>> Lotus. >>>>> >>>>> Approach works in Windows XP and SBS 2003. The swarticons are on the >>>>> hard drive. >>>>> >>>>> I even found the *.smi and re-associated them with Lotus Approach. >>>>> >>>>> Any suggestions besides re-install Lotus. >>>>> >>>>> thanks >>>>> >>>> >>> >> > |
| | #9 (permalink) |
| | Re: Lotus Approach from Smartsuite 9.8 - need help IBM - Lotus applications such as WordPro, 1-2-3, Freelance, Approach, CC: Mail - and the most famous of them all NOTES. Corel - WordPerfect Office, Quattro Pro, Presentations, Corel Central. -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "Zack Whittaker" <admin@zacknet.co.uk> wrote in message news:uW$9WhVaGHA.3740@TK2MSFTNGP03.phx.gbl... > Contact the manufacture (Corel now I believe) and see what their plans are > for Vista in the future. > Lotus has always been a bit funny - we have it running on our server as a > DTP product and it's no match for Office to be honest. > > -- > Zack Whittaker > » ZackNET Enterprises: www.zacknet.co.uk > » MSBlog on ResDev: www.msblog.org > » Vista Knowledge Base: www.vistabase.co.uk > » This mailing is provided "as is" with no warranties, and confers no > rights. All opinions expressed are those of myself unless stated so, and > not > of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared > that up! > > --: Original message follows :-- > "Andre Da Costa [Extended64]" <andred25@hotmail.com> wrote in message > news:OVoBBBOaGHA.4060@TK2MSFTNGP02.phx.gbl... >>I think this is where IBM Lotus Development, please contact them about >>Windows Vista support or updates for the application to support Vista. >> -- >> -- >> Andre >> Windows Connected | http://www.windowsconnected.com >> Extended64 | http://www.extended64.com >> Blog | http://www.extended64.com/blogs/andre >> http://spaces.msn.com/members/adacosta >> >> "David Sherman" <dshermin@ameritech.net> wrote in message >> news:vgms42l4pd1hp98dtq2jqfjlnbcunf69mm@4ax.com... >>> yes, I did. >>> >>>>Have you tried running it in compatibility. Check the properties of the >>>>executable under > Compatibility (tab). >>>> >>>>-- >>>>-- >>>>Andre >>>>Windows Connected | http://www.windowsconnected.com >>>>Extended64 | http://www.extended64.com >>>>Blog | http://www.extended64.com/blogs/andre >>>>http://spaces.msn.com/members/adacosta >>>> >>>>"David Sherman" <dshermin@ameritech.net> wrote in message >>>>news:kjcs42tharra9m11u38gp2diikh28uv5eh@4ax.com... >>>>> All the files in the latest Lotus Smartsuite 9.8 run except for >>>>> Approach. Error messge : >>>>> "could not find smarticons. Please run install.exe to re-install >>>>> Lotus. >>>>> >>>>> Approach works in Windows XP and SBS 2003. The swarticons are on the >>>>> hard drive. >>>>> >>>>> I even found the *.smi and re-associated them with Lotus Approach. >>>>> >>>>> Any suggestions besides re-install Lotus. >>>>> >>>>> thanks >>>>> >>>> >>> >> >> > > |
| | #10 (permalink) |
| | Re: Lotus Approach from Smartsuite 9.8 - need help Its running nicely on my 95 machine at home here. ![]() -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "David Sherman" <dshermin@ameritech.net> wrote in message news:9uiv42h2uh6m4qimmna5mbp08baqutkt9f@4ax.com... > IBM support has no answer. I expect that there will be a new version > next year. > I agree the Lotus Smartsuite is a dead program with little future. > > > On Wed, 26 Apr 2006 18:39:18 +0100, "Zack Whittaker" > <admin@zacknet.co.uk> wrote: > >>Contact the manufacture (Corel now I believe) and see what their plans are >>for Vista in the future. >>Lotus has always been a bit funny - we have it running on our server as a >>DTP product and it's no match for Office to be honest. >> >>-- >>Zack Whittaker >>» ZackNET Enterprises: www.zacknet.co.uk >>» MSBlog on ResDev: www.msblog.org >>» Vista Knowledge Base: www.vistabase.co.uk >>» This mailing is provided "as is" with no warranties, and confers no >>rights. All opinions expressed are those of myself unless stated so, and >>not >>of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared >>that up! >> >> --: Original message follows :-- >>"Andre Da Costa [Extended64]" <andred25@hotmail.com> wrote in message >>news:OVoBBBOaGHA.4060@TK2MSFTNGP02.phx.gbl... >>>I think this is where IBM Lotus Development, please contact them about >>>Windows Vista support or updates for the application to support Vista. >>> -- >>> -- >>> Andre >>> Windows Connected | http://www.windowsconnected.com >>> Extended64 | http://www.extended64.com >>> Blog | http://www.extended64.com/blogs/andre >>> http://spaces.msn.com/members/adacosta >>> >>> "David Sherman" <dshermin@ameritech.net> wrote in message >>> news:vgms42l4pd1hp98dtq2jqfjlnbcunf69mm@4ax.com... >>>> yes, I did. >>>> >>>>>Have you tried running it in compatibility. Check the properties of the >>>>>executable under > Compatibility (tab). >>>>> >>>>>-- >>>>>-- >>>>>Andre >>>>>Windows Connected | http://www.windowsconnected.com >>>>>Extended64 | http://www.extended64.com >>>>>Blog | http://www.extended64.com/blogs/andre >>>>>http://spaces.msn.com/members/adacosta >>>>> >>>>>"David Sherman" <dshermin@ameritech.net> wrote in message >>>>>news:kjcs42tharra9m11u38gp2diikh28uv5eh@4ax.com... >>>>>> All the files in the latest Lotus Smartsuite 9.8 run except for >>>>>> Approach. Error messge : >>>>>> "could not find smarticons. Please run install.exe to re-install >>>>>> Lotus. >>>>>> >>>>>> Approach works in Windows XP and SBS 2003. The swarticons are on the >>>>>> hard drive. >>>>>> >>>>>> I even found the *.smi and re-associated them with Lotus Approach. >>>>>> >>>>>> Any suggestions besides re-install Lotus. >>>>>> >>>>>> thanks >>>>>> >>>>> >>>> >>> >>> >> > |
| Maybe I should try a different approach | VB Script | |||
| Lotus SmartSuite | Vista General | |||
| Is this is the correct REST approach? | .NET General | |||
| A different upgrade approach | Vista General | |||
