| | Wireless Internet Connection Hi there, i'm having some problems with my wireless connection. My Vista PC says that i'm connected to the router and the internet, but I can't get into the web. I reseted the router but nothing chaned. The explorer page gives me this error: ieframe.dll/dnserror.htm. I googled that error and i found a lot of forums about it, but no one has a solution. Has anybody had the same problem? And maybe the way to repair it!? Thanks a lot |
| | Re: Wireless Internet Connection Hi, Did it work before? Does it (the router) work with other machines? Are you being assigned an IP (ipconfig /all)? Have you flushed the dns cache yet (ipconfig /flushdns)? Is it just IE or are other net-linked functions blocked? -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Gonzalo" <Gonzalo@xxxxxx> wrote in message news:E9C5F75E-BEDB-485D-916D-4B4F55C9FC41@xxxxxx Quote: > Hi there, i'm having some problems with my wireless connection. My Vista > PC > says that i'm connected to the router and the internet, but I can't get > into > the web. I reseted the router but nothing chaned. The explorer page gives > me > this error: ieframe.dll/dnserror.htm. > I googled that error and i found a lot of forums about it, but no one has > a > solution. > Has anybody had the same problem? And maybe the way to repair it!? > Thanks a lot |
| | Re: Wireless Internet Connection Hi Rick, It's a new PC, the first day, explerer worked with a cell phone connection, never gone with the router. I can't get connected to anything, messenger, symantec, etc... I have 2 other PC with win XP that work without any problem. Sorry,but ihave no idea on how to flush the dns cache. Thanks "Rick Rogers" wrote: Quote: > Hi, > > Did it work before? > Does it (the router) work with other machines? > Are you being assigned an IP (ipconfig /all)? > Have you flushed the dns cache yet (ipconfig /flushdns)? > Is it just IE or are other net-linked functions blocked? > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "Gonzalo" <Gonzalo@xxxxxx> wrote in message > news:E9C5F75E-BEDB-485D-916D-4B4F55C9FC41@xxxxxx Quote: > > Hi there, i'm having some problems with my wireless connection. My Vista > > PC > > says that i'm connected to the router and the internet, but I can't get > > into > > the web. I reseted the router but nothing chaned. The explorer page gives > > me > > this error: ieframe.dll/dnserror.htm. > > I googled that error and i found a lot of forums about it, but no one has > > a > > solution. > > Has anybody had the same problem? And maybe the way to repair it!? > > Thanks a lot > |
| | Re: Wireless Internet Connection Hi, Click start and type CMD, then right click the command entry in the program menu and select 'run as administrator'. This will open an elevated command prompt. From the prompt, run "ipconfig /all" and report back with the following lines: Node Type IPv4 address Default Gateway DHCP server -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Gonzalo" <Gonzalo@xxxxxx> wrote in message news:991E37E2-5EBE-4208-BAE2-2C0CF0FE578B@xxxxxx Quote: > Hi Rick, > It's a new PC, the first day, explerer worked with a cell phone > connection, > never gone with the router. I can't get connected to anything, messenger, > symantec, etc... > I have 2 other PC with win XP that work without any problem. > Sorry,but ihave no idea on how to flush the dns cache. > Thanks > > "Rick Rogers" wrote: > Quote: >> Hi, >> >> Did it work before? >> Does it (the router) work with other machines? >> Are you being assigned an IP (ipconfig /all)? >> Have you flushed the dns cache yet (ipconfig /flushdns)? >> Is it just IE or are other net-linked functions blocked? >> >> -- >> Best of Luck, >> >> Rick Rogers, aka "Nutcase" - Microsoft MVP >> http://mvp.support.microsoft.com/ >> Windows help - www.rickrogers.org >> My thoughts http://rick-mvp.blogspot.com >> >> "Gonzalo" <Gonzalo@xxxxxx> wrote in message >> news:E9C5F75E-BEDB-485D-916D-4B4F55C9FC41@xxxxxx Quote: >> > Hi there, i'm having some problems with my wireless connection. My >> > Vista >> > PC >> > says that i'm connected to the router and the internet, but I can't get >> > into >> > the web. I reseted the router but nothing chaned. The explorer page >> > gives >> > me >> > this error: ieframe.dll/dnserror.htm. >> > I googled that error and i found a lot of forums about it, but no one >> > has >> > a >> > solution. >> > Has anybody had the same problem? And maybe the way to repair it!? >> > Thanks a lot >> |
| | Re: Wireless Internet Connection Thanks Rick, i found it. Everything looks normal to me. "Rick Rogers" wrote: Quote: > Hi, > > Click start and type CMD, then right click the command entry in the program > menu and select 'run as administrator'. This will open an elevated command > prompt. From the prompt, run "ipconfig /all" and report back with the > following lines: > > Node Type > IPv4 address > Default Gateway > DHCP server > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "Gonzalo" <Gonzalo@xxxxxx> wrote in message > news:991E37E2-5EBE-4208-BAE2-2C0CF0FE578B@xxxxxx Quote: > > Hi Rick, > > It's a new PC, the first day, explerer worked with a cell phone > > connection, > > never gone with the router. I can't get connected to anything, messenger, > > symantec, etc... > > I have 2 other PC with win XP that work without any problem. > > Sorry,but ihave no idea on how to flush the dns cache. > > Thanks > > > > "Rick Rogers" wrote: > > Quote: > >> Hi, > >> > >> Did it work before? > >> Does it (the router) work with other machines? > >> Are you being assigned an IP (ipconfig /all)? > >> Have you flushed the dns cache yet (ipconfig /flushdns)? > >> Is it just IE or are other net-linked functions blocked? > >> > >> -- > >> Best of Luck, > >> > >> Rick Rogers, aka "Nutcase" - Microsoft MVP > >> http://mvp.support.microsoft.com/ > >> Windows help - www.rickrogers.org > >> My thoughts http://rick-mvp.blogspot.com > >> > >> "Gonzalo" <Gonzalo@xxxxxx> wrote in message > >> news:E9C5F75E-BEDB-485D-916D-4B4F55C9FC41@xxxxxx > >> > Hi there, i'm having some problems with my wireless connection. My > >> > Vista > >> > PC > >> > says that i'm connected to the router and the internet, but I can't get > >> > into > >> > the web. I reseted the router but nothing chaned. The explorer page > >> > gives > >> > me > >> > this error: ieframe.dll/dnserror.htm. > >> > I googled that error and i found a lot of forums about it, but no one > >> > has > >> > a > >> > solution. > >> > Has anybody had the same problem? And maybe the way to repair it!? > >> > Thanks a lot > >> > >> > |
| | #6 (permalink) |
| Vista Home Premium 32bit | Re: Wireless Internet Connection Hi I have a similar probled. Please could you let me know exactly what you did. This may halp me connect my vista pc to my D-Link router Thanks |
| | #7 (permalink) |
| | Re: Wireless Internet Connection I flushed it, but everything is the same. Thanks a lot Rick "Gonzalo" wrote: Quote: > Thanks Rick, i found it. > Everything looks normal to me. > > "Rick Rogers" wrote: > Quote: > > Hi, > > > > Click start and type CMD, then right click the command entry in the program > > menu and select 'run as administrator'. This will open an elevated command > > prompt. From the prompt, run "ipconfig /all" and report back with the > > following lines: > > > > Node Type > > IPv4 address > > Default Gateway > > DHCP server > > > > -- > > Best of Luck, > > > > Rick Rogers, aka "Nutcase" - Microsoft MVP > > http://mvp.support.microsoft.com/ > > Windows help - www.rickrogers.org > > My thoughts http://rick-mvp.blogspot.com > > > > "Gonzalo" <Gonzalo@xxxxxx> wrote in message > > news:991E37E2-5EBE-4208-BAE2-2C0CF0FE578B@xxxxxx Quote: > > > Hi Rick, > > > It's a new PC, the first day, explerer worked with a cell phone > > > connection, > > > never gone with the router. I can't get connected to anything, messenger, > > > symantec, etc... > > > I have 2 other PC with win XP that work without any problem. > > > Sorry,but ihave no idea on how to flush the dns cache. > > > Thanks > > > > > > "Rick Rogers" wrote: > > > > > >> Hi, > > >> > > >> Did it work before? > > >> Does it (the router) work with other machines? > > >> Are you being assigned an IP (ipconfig /all)? > > >> Have you flushed the dns cache yet (ipconfig /flushdns)? > > >> Is it just IE or are other net-linked functions blocked? > > >> > > >> -- > > >> Best of Luck, > > >> > > >> Rick Rogers, aka "Nutcase" - Microsoft MVP > > >> http://mvp.support.microsoft.com/ > > >> Windows help - www.rickrogers.org > > >> My thoughts http://rick-mvp.blogspot.com > > >> > > >> "Gonzalo" <Gonzalo@xxxxxx> wrote in message > > >> news:E9C5F75E-BEDB-485D-916D-4B4F55C9FC41@xxxxxx > > >> > Hi there, i'm having some problems with my wireless connection. My > > >> > Vista > > >> > PC > > >> > says that i'm connected to the router and the internet, but I can't get > > >> > into > > >> > the web. I reseted the router but nothing chaned. The explorer page > > >> > gives > > >> > me > > >> > this error: ieframe.dll/dnserror.htm. > > >> > I googled that error and i found a lot of forums about it, but no one > > >> > has > > >> > a > > >> > solution. > > >> > Has anybody had the same problem? And maybe the way to repair it!? > > >> > Thanks a lot > > >> > > >> > > |
| | #8 (permalink) |
| | Re: Wireless Internet Connection Hi, i followed the instructions that Rick gave me, you con read them in this topic. I still can't get to use internet. Try reseting the router, sometimes it works. "Scaddows" wrote: Quote: > > Hi > > I have a similar probled. Please could you let me know exactly what you > did. This may halp me connect my vista pc to my D-Link router > > Thanks > > > -- > Scaddows > |
| | #9 (permalink) |
| Vista Home Premium 32bit | Re: Wireless Internet Connection Thanks Gonzalo http://www.vistax64.com/network-inte...tml#post556362 http://www.vistax64.com/network-inte...s-trouble.html Keep an eye on these two and we may get an answer. I have also emails DLink, but do not expect much help back. Thanks |
| | #10 (permalink) |
| | Re: Wireless Internet Connection Thanks for the links Scaddows. I'll let you know as soon as i try. "Scaddows" wrote: Quote: > > Thanks Gonzalo > > http://www.vistax64.com/network-inte...tml#post556362 > > http://www.vistax64.com/network-inte...s-trouble.html > > > Keep an eye on these two and we may get an answer. I have also emails > DLink, but do not expect much help back. > > Thanks > > > -- > Scaddows > |
| wireless internet connection | Network & Sharing | |||
| Internet wireless connection | Vista General | |||
| wireless internet connection | Vista General | |||
| Wireless Internet Connection | Vista networking & sharing | |||
| Wireless internet connection. | Vista General | |||
