| | How to check hdd's SMART data? One of my hdd's started to occasionally give strange sound, so I want to check "Reallocated sectors count" and other SMART data. Unfortunately neither Speedfan nor Everest Home Edition can't show Smart under my Vista (SP0). What is the way to read SMART having only Vista Home Premium 32 installed? I wonder if installing nForce drivers from nVidia website or alternatively SP1 RC will help? However I am afraid that nforce drivers from nVidia website might destroy my system. Allternatively maybe there is a bootable fdd/cd image on Internet to read smart ? Mark |
| | Re: How to check hdd's SMART data? First post, so bear with me.... Try Western Digital's free windows diagnostic software, it will allow you to see all of the hd smart information, and it works in Vista w/o problems. "Netx" <user72cut-it-out@xxxxxx> wrote in message news:OeBD23jSIHA.1164@xxxxxx Quote: > One of my hdd's started to occasionally give strange sound, so I want to > check "Reallocated sectors count" and other SMART data. Unfortunately > neither Speedfan nor Everest Home Edition can't show Smart under my Vista > (SP0). What is the way to read SMART having only Vista Home Premium 32 > installed? > > I wonder if installing nForce drivers from nVidia website or alternatively > SP1 RC will help? However I am afraid that nforce drivers from nVidia > website might destroy my system. > Allternatively maybe there is a bootable fdd/cd image on Internet to read > smart ? > > Mark |
| | Re: How to check hdd's SMART data? Thanks for all response. Unfortunately I found out that all smart-displaying software won't work under Vista with my nForce 570 Sli chipset. This is due to drivers. However under Windows Xp such software worked OK showing smart. (however currently I have only licence for Vista Premium box). Now the problem is that I can't tell which of 2 installed disks makes trouble to return it on warranty. It gives sort of "metal to metal friction" noise for *only* several seconds a day. It started when I was making full backup to usb device, two days ago, and heads were moving constantly for about two hours. Also I suppose that when I return it on warranty (to the shop), the strange sound may not be emited. I decided to carry on with both HDDs until one will die definitely. I make incremental backup every day. Mark |
| Making two HDD's appears as one | Vista General | |||
| SATA hdd's | Vista hardware & devices | |||
| Slow HDD's | Vista file management | |||
| Can I find out exactly what my HDD's doing?! | Vista General | |||
| How Often To Defragment HDD's? | Vista General | |||
