| Guest | Problem installing americas army game I am trying to install americas army the game on my new laptop. i have 32bit vista basic installed. when it gets to the beginning of the installation i get an error message: "Failed to install ISkernel Files. Make sure you have appropriate privileges on this computer." i really want this game installed asap, but can't figure out how to get around this message. any help would be greatly appreciated thanks |
| Guest | Re: Problem installing americas army game Try running the application in Compatibility mode to see if it will work (full 32-bit application applications supported). Right click the programs executable > click Properties > "Compatibility" tab > under "Compatibility Mode" check the Run this application in compatibility mode for: box > click in the list box and choose a suitable version of Windows. Certain applications might encounter problems with the new User Account Control security component in Vista because the application was designed to run with Administrative privileges. You can try a work around by, right clicking the applications executable and click "Run as Administrator" on the context menu. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "spike1803356" <spike1803356@xxxxxx> wrote in message news:608D783E-4ADD-4457-8C4D-F68AF5DA146B@xxxxxx Quote: >I am trying to install americas army the game on my new laptop. i have >32bit > vista basic installed. when it gets to the beginning of the installation i > get an error message: > > "Failed to install ISkernel Files. Make sure you have appropriate > privileges > on this computer." > > i really want this game installed asap, but can't figure out how to get > around this message. > > any help would be greatly appreciated > > thanks |
| Guest | Re: Problem installing americas army game it's ok, i turned of UAC's and it works now. thanks for the help though ![]() "Andre Da Costa[ActiveWin]" wrote: Quote: > Try running the application in Compatibility mode to see if it will work > (full 32-bit application applications supported). Right click the programs > executable > click Properties > "Compatibility" tab > under "Compatibility > Mode" check the Run this application in compatibility mode for: box > click > in the list box and choose a suitable version of Windows. > > Certain applications might encounter problems with the new User Account > Control security component in Vista because the application was designed to > run with Administrative privileges. You can try a work around by, right > clicking the applications executable and click "Run as Administrator" on the > context menu. > -- > Andre > Blog: http://adacosta.spaces.live.com > My Vista Quickstart Guide: > http://adacosta.spaces.live.com/blog...3DB!9709.entry > > "spike1803356" <spike1803356@xxxxxx> wrote in message > news:608D783E-4ADD-4457-8C4D-F68AF5DA146B@xxxxxx Quote: > >I am trying to install americas army the game on my new laptop. i have > >32bit > > vista basic installed. when it gets to the beginning of the installation i > > get an error message: > > > > "Failed to install ISkernel Files. Make sure you have appropriate > > privileges > > on this computer." > > > > i really want this game installed asap, but can't figure out how to get > > around this message. > > > > any help would be greatly appreciated > > > > thanks > > |
| Cannot install the game "Americas Army" on HP laptop. | Gaming | |||
| installing americas army | Vista Games | |||
| installing americas army | Gaming | |||
| Americas Army Special Forces | Vista Games | |||
| Americas Army Will Not Install | Vista Games | |||
