Vista - USB DEVICES NOT ALWAYS RECOGNISED
Old 12-30-2007   #1 (permalink)
Mike D
Hi, I have vista ultimate and sometimes when I plug in a device I know I have
installed and was working it asks me for the drivers again, I search the
local computer but it doesn't find them, I thought it was only when I plugged
the device into a different port put it seems to just be random, anyone help?
Thanks
Old 12-30-2007   #2 (permalink)
Andre Da Costa[ActiveWin]
Re: USB DEVICES NOT ALWAYS RECOGNISED
Try updating your chipset drivers, go the manufacturers website.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"Mike D" <MikeD@xxxxxx> wrote in message
news:030E990C-4965-46F8-8539-89241B97F5E4@xxxxxx
> have
> plugged
> help?
> Thanks
Old 12-30-2007   #3 (permalink)
alexB
I've got the same problem on and off but pretty much 98% of the time.
Looking for a solution quite by accident I just found in Install/Uninstall
Windows Components "Manage Removable Storage Devices" or something to this
effect. It was unchecked. I checked it but it will be about 18 hours before
I can find out if it really worked. I've got Ultimate but had it also in XP
all the way.
> have
> plugged
> help?
> Thanks
USB hardware not recognised warnings - when theres no USB devices Vista hardware & devices
USB Devices not not working or recognised following vista updates Vista hardware & devices
Vista Generic USB storage devices not recognised Vista hardware & devices
USB Devices not recognised post removal Vista hardware & devices
USB devices not recognised Vista hardware & devices
