| | Shift+Tab does not work When I press SHIFT + TAB to go To the previous tab, nothing happens. Is that a Vista error? This problem appears since last week. Before it used to work normal. I bought my computer and keyboard in february this year. It is strange that Shift+Tab used to work and since last week it stopped working. Other functions with Shift seem to work normal. It is only a problem when using Shift+ TaB. Anyone have the same experience? Thanks! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Shift+Tab does not work When I press SHIFT + TAB to go To the previous tab, nothing happens. Is that a Vista error? This problem appears since last week. Before it used to work normal. I bought my computer and keyboard in february this year. It is strange that Shift+Tab used to work and since last week it stopped working. Other functions with Shift seem to work normal. It is only a problem when using Shift+ TaB. Anyone have the same experience? Thanks! Use SHIFT+TAB to get to the tab location, then use the left and right arrow keys to move between them. Shawn |
| | Re: Shift+Tab does not work i just removed the the windows live toolbar from my programs and the problem seems to be solved. -- sylvia Posted via http://www.vistaheads.com |
| Question about bit shift | .NET General | |||
| Preventing Excel Auto_Open() Macro runnng on vpc -Holding "Shift" doesn't work | Virtual Server | |||
| shift of view | Vista General | |||
| shift key problems | Vista General | |||
| time shift on 64-bit | Vista Games | |||
