| | Power Options is Missing I just installed Vista Business on an HP m8100n, and when I click on power options nothing shows up. I also get a shell error. The error code is 'shell:::{26EEO668-A00A-44D7-9371-BEB064C98683}\2\::{025A5937-A6B...\pageGlobalSettings' Any Help Would be Appreciated. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options is Missing Try running a "sfc /scannow" (no quotes) command to see if it can find and fix the error for you. This will show you how. http://www.vistax64.com/tutorials/66...tem-files.html Hope it helps you, Shawn |
| | Re: Power Options is Missing I ran the check and it came back with corrupted files. I checked the CBS log to find out what they were because Windows could not fix the files. The two files are powercpl.dll and pnidui.dll. I download the dll's off the internet and put them in the system32 folder. But Vista won't allow me to take out the corrupted versions. I am logged on as the administrator and I tried to change the permissions of the files, but that didn't work either. Once again any help would be appreciated. -Ross |
| | Re: Power Options is Missing Try repairing your installation using the Windows Vista installation DVD. Boot from your Windows Vista DVD, select the System Repair Option > on the setup screen, select 'Repair Computer > Select your installation of Windows Quote: > select Startup Repair option and follow instructions. Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "Ross" <Ross@xxxxxx> wrote in message news:F40682F7-0703-47A6-B5F6-062613A84951@xxxxxx Quote: >I ran the check and it came back with corrupted files. I checked the CBS >log > to find out what they were because Windows could not fix the files. The > two > files are powercpl.dll and pnidui.dll. I download the dll's off the > internet > and put them in the system32 folder. But Vista won't allow me to take out > the > corrupted versions. I am logged on as the administrator and I tried to > change > the permissions of the files, but that didn't work either. > > Once again any help would be appreciated. > > -Ross |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options is Missing I ran the check and it came back with corrupted files. I checked the CBS log to find out what they were because Windows could not fix the files. The two files are powercpl.dll and pnidui.dll. I download the dll's off the internet and put them in the system32 folder. But Vista won't allow me to take out the corrupted versions. I am logged on as the administrator and I tried to change the permissions of the files, but that didn't work either. Once again any help would be appreciated. -Ross You will need to take ownership of them first, then you should be able to delete them. Take Ownership of file Shawn |
| | #6 (permalink) |
| | Re: Power Options is Missing Thank You everyone for your help. I got it to work. |
| | #7 (permalink) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power Options is Missing Your welcome Ross, Glad to hear you got it working. Thank you for the feedback. Shawn |
Power Options Corrupt (power plan unavailable) | General Discussion | |||
| Useful tool for power enthusiasts on the go (advanced power options) | General Discussion | |||
| power options missing in vista x64 | Vista General | |||
| Vista Ultimate:Battery tab missing on Power Options - Advanced set | Vista General | |||
| Power Management/Power Options in Vista | Vista General | |||
