| vista home basic | Memory problems I ran memtest and in the first 16 minutes it found 505880 errors. I know this means bad. But how bad is it? Is there any way I can fix it other than replacing the 1 GB memory I installed there? Thank you so much in advance. |
| | Re: Memory problems Hi, It's bad, and there is no way to fix it beyond replacing it. If there are multiple sticks, you want to rerun the tests with each stick individually to isolate which one is the problem. Their is a slim chance that a stick may have become unseated, you might want to open the system and see if a stick is not fully seated or has come loose. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "asiandoll" <asiandoll.32g9h1@xxxxxx-mx.forums.net> wrote in message news:asiandoll.32g9h1@xxxxxx-mx.forums.net... Quote: > > I ran memtest and in the first 16 minutes it found 505880 errors. I know > this means bad. But how bad is it? > > Is there any way I can fix it other than replacing the 1 GB memory I > installed there? > > Thank you so much in advance. > > > -- > asiandoll |
| | Re: Memory problems "asiandoll" <asiandoll.32g9h1@xxxxxx-mx.forums.net> wrote in message news:asiandoll.32g9h1@xxxxxx-mx.forums.net... Quote: > > I ran memtest and in the first 16 minutes it found 505880 errors. I know > this means bad. But how bad is it? > > Is there any way I can fix it other than replacing the 1 GB memory I > installed there? > > Thank you so much in advance. > > > -- > asiandoll Re memory, there are no shades of bad. It is either good and installed, or bad and in the trash can.. -- Mike Hall - MVP http://msmvps.com/blogs/mikehall/default.aspx |
| | Re: Memory problems asiandoll wrote: Quote: > I ran memtest and in the first 16 minutes it found 505880 errors. I > know this means bad. But how bad is it? > > Is there any way I can fix it other than replacing the 1 GB memory I > installed there? > > Thank you so much in advance. need any help from here, do you ? .. |
| | Re: Memory problems In article <asiandoll.32g9h1@xxxxxx-mx.forums.net>, asiandoll <asiandoll.32g9h1@xxxxxx-mx.forums.net> wrote: Quote: > > >Is there any way I can fix it other than replacing the 1 GB memory I >installed there? > |
| | #6 (permalink) |
| | Re: Memory problems "bomb#20" wrote: Quote: > asiandoll wrote: Quote: > > I ran memtest and in the first 16 minutes it found 505880 errors. I > > know this means bad. But how bad is it? > > > > Is there any way I can fix it other than replacing the 1 GB memory I > > installed there? > > > > Thank you so much in advance. > If you know what Memtest is and when to run it, then you don't > need any help from here, do you ? > .. > > > Jesus, you're one sarcastic SOB, aren't you? Not much help either. Your statement wasn't exactly packed with advice. asiandoll was given the proper advice by the other contributors to this thread. Jane C, Mr. Rogers, Mr. Da Costa and Mr. Hall all gave the proper advice. You contributed nothing. Did I contribute anything of value to the thread? Probably not, other than to state my opinion that you're a jerk. Have a nice day. C.B. |
| Memory problems | Vista hardware & devices | |||
| Memory problems...? | General Discussion | |||
| 2 different vista problems. Memory dump crash and startup repair cannot fix problems | Vista General | |||
| memory problems with 4 gb ram | General Discussion | |||
| Memory Problems | Vista hardware & devices | |||
