| | Volume shadow copy Why is the service turned on by default? thanks |
| | Re: Volume shadow copy To protect your files, so you can revert to a previous version of a file that probably became corrupt. In build 5231, I had a photo I loved so much that was accidently corrupted after I tried to convert it to PNG, I simply converted it by going to the properties of the file, volume shadow tab. This feature was previously only available in Windows Server 2003. -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "David Sherman" <dshermin@ameritech.net> wrote in message news:kc2t4215c95bgmnhardosroa6vfdslce08@4ax.com... > Why is the service turned on by default? > > thanks |
| | Re: Volume shadow copy Andre Da Costa [Extended64] wrote: > To protect your files, so you can revert to a previous version of a > file that probably became corrupt. In build 5231, I had a photo I > loved so much that was accidently corrupted after I tried to convert > it to PNG, I simply converted it by going to the properties of the > file, volume shadow tab. This feature was previously only available > in Windows Server 2003. -- Well as you probably remember, the service doesn't start by default in Windows 2003, it is left in the manual state and is only called when it is actually being used. So either there is an issue here or VSS works slightly differently in Longhorn, so its a fair question either way. |
| | Re: Volume shadow copy How does it work with Server 2003 and SB2003? I wonder also how this reactes with Diskkeeper 9 when doing a defrag. When I lasted checked it, 3rd party defrag tools would not work the Volume Shadow Copy turned on a Server. On Tue, 25 Apr 2006 22:16:26 +0100, "Robert Moir" <robspamtrap+msnews@gmail.com> wrote: >Andre Da Costa [Extended64] wrote: >> To protect your files, so you can revert to a previous version of a >> file that probably became corrupt. In build 5231, I had a photo I >> loved so much that was accidently corrupted after I tried to convert >> it to PNG, I simply converted it by going to the properties of the >> file, volume shadow tab. This feature was previously only available >> in Windows Server 2003. -- > >Well as you probably remember, the service doesn't start by default in >Windows 2003, it is left in the manual state and is only called when it is >actually being used. > >So either there is an issue here or VSS works slightly differently in >Longhorn, so its a fair question either way. > |
| | Re: Volume shadow copy In a Server environment its different, you would enable it on a back up Server or SAN, so it would configured to automatically create previous versions of all client user files files in the domain. Although this would be determined by a qouta and what file types can be backed up. -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "David Sherman" <dshermin@ameritech.net> wrote in message news:mmjv42hur2sm0bm57geis71q2fijj6o93a@4ax.com... > How does it work with Server 2003 and SB2003? > > I wonder also how this reactes with Diskkeeper 9 when doing a defrag. > When I lasted checked it, 3rd party defrag tools would not work the > Volume Shadow Copy turned on a Server. > > > On Tue, 25 Apr 2006 22:16:26 +0100, "Robert Moir" > <robspamtrap+msnews@gmail.com> wrote: > >>Andre Da Costa [Extended64] wrote: >>> To protect your files, so you can revert to a previous version of a >>> file that probably became corrupt. In build 5231, I had a photo I >>> loved so much that was accidently corrupted after I tried to convert >>> it to PNG, I simply converted it by going to the properties of the >>> file, volume shadow tab. This feature was previously only available >>> in Windows Server 2003. -- >> >>Well as you probably remember, the service doesn't start by default in >>Windows 2003, it is left in the manual state and is only called when it is >>actually being used. >> >>So either there is an issue here or VSS works slightly differently in >>Longhorn, so its a fair question either way. >> > |
| | #6 (permalink) |
| | Re: Volume shadow copy Andre Da Costa [Extended64] wrote: > In a Server environment its different, you would enable it on a back > up Server or SAN, so it would configured to automatically create > previous versions of all client user files files in the domain. > Although this would be determined by a qouta and what file types can > be backed up. -- Andre, as far as I know, Volume Shadow copies run locally to the server. You would have a server with two volumes (ideally different spindles), place your shares on one volume and use the other for the shadow copies. As far as I know, you can't do this over multiple servers, e.g. you seem to be proposing that Windows 2003 lets you pick a "Volume Shadow Copies Server" for your whole domain which shadows every share you choose on any server on the network... and I don't think it works that way. -- -- Rob Moir, Microsoft MVP Blog Site - http://www.robertmoir.com Virtual PC 2004 FAQ - http://www.robertmoir.co.uk/win/VirtualPC2004FAQ.html I'm always surprised at "professionals" who STILL have to be asked "Have you checked (event viewer / syslog)". |
| | #7 (permalink) |
| | Re: Volume shadow copy David Sherman wrote: > How does it work with Server 2003 and SB2003? General info about VSS here: http://www.robertmoir.co.uk/win/ShadowCopiesFAQ.html The machine takes a 'snapshot' of the various volumes at a time chose by the admin, and copies the difference in the files to the shadow. For backup programs that can use the VSS service, these take a snapshot of the object(s) being copied in the same way, and write the shadow copy out to the backup media. > I wonder also how this reactes with Diskkeeper 9 when doing a defrag. > When I lasted checked it, 3rd party defrag tools would not work the > Volume Shadow Copy turned on a Server. The defrag tools were protecting you http://support.microsoft.com/default...b;en-us;312067 (*sigh* I should add this to my VSS FAQ sometime...) -- -- Rob Moir, Microsoft MVP Blog Site - http://www.robertmoir.com Virtual PC 2004 FAQ - http://www.robertmoir.co.uk/win/VirtualPC2004FAQ.html I'm always surprised at "professionals" who STILL have to be asked "Have you checked (event viewer / syslog)". |
| (VSS)Volume Shadow copy | Vista General | |||
| problems with volume shadow copy service | Vista performance & maintenance | |||
| Volume Shadow Copy - Can it be turned off | Vista performance & maintenance | |||
| VSS (Volume Shadow Copy Service) | Vista General | |||
| How do you stop Volume Shadow copy | Vista General | |||
