Vista - Operating System Not Found
Old 01-01-2008   #1 (permalink)
gavtheunchav
since this morning, as i boot my laptop (Vista) it says that the operating
system cannot be found... any ideas on how to fix this? Thanks
Old 01-01-2008   #2 (permalink)
Rick Rogers
Re: Operating System Not Found
Leave a disk in the CD/DVD drive?
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"gavtheunchav" <gavtheunchav@xxxxxx> wrote in message
newsEED68D3-ADB4-4099-AE3C-7920854DAE7A@xxxxxx
Old 01-01-2008   #3 (permalink)
Meinolf Weber
Hello gavtheunchav,
Check that no USB or disk is connected during startup, that can block the
startup. Did you install/change anything before the shutdwon?
Best regards
Meinolf Weber
Disclaimer: This posting is provided "AS IS" with no warranties, and confers
no rights.
** Please do NOT email, only reply to Newsgroups
** HELP us help YOU!!! http://www.dts-l.org/goodpost.htm
> operating system cannot be found... any ideas on how to fix this?
> Thanks
Old 01-01-2008   #4 (permalink)
gavtheunchav
Thanks for the idea Rick but that did not work.
it also says:
"PXE-E61: Media test failure, check cable
PXE-MOF: Exiting Broadcom PXE ROM
Operating System Not found"
Any more ideas? Thanks gav
"Rick Rogers" wrote:
Quote:
> Hi,
> Best of Luck,
Old 01-01-2008   #5 (permalink)
Ken Blake, MVP
On Tue, 1 Jan 2008 11:27:06 -0800, gavtheunchav
Check to make you didn't leave a bootable CD or diskette inserted.
If not, it would seem that the hard drive has died.
Ken Blake, Microsoft MVP Windows - Shell/User
Please Reply to the Newsgroup
Old 01-01-2008   #6 (permalink)
Rick Rogers
Then either the cabling is loose or the hard drive died.
Best of Luck,
news:E4B263EE-575B-4D4B-991F-7D8E1F3841B1@xxxxxx
> it also says:
Quote:
>> Hi,
>> Best of Luck,
>> > operating
Old 01-01-2008   #7 (permalink)
gavtheunchav
Dont think i installed anything before shutting down and i have tried to
start it up with and without a CD. and no luck. Looking like i may need a new
laptop.. Thanks Gav
"Ken Blake, MVP" wrote:
Quote:
> On Tue, 01 Jan 2008 12:42:03 -0700, "Ken Blake, MVP"
> Sorry, I meant a *non*-bootable CD or diskette, of course.
Old 01-01-2008   #8 (permalink)
gavtheunchav
im pretty rubbish with computers. is it worth getting it repaired if the hard
drive is dead? or getting another one on the guartenee? Thanks
> laptop.. Thanks Gav
Old 01-01-2008   #9 (permalink)
Andre Da Costa[ActiveWin]
If the hard disk is dead, repairing is pretty much a waste of time, you
could try getting the data recovered and backed up then install a new drive.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
news:7E6040E2-6BB7-4D06-A51E-C15231BED31D@xxxxxx
> hard
>> new
>> laptop.. Thanks Gav
>> > > > operating
Old 01-01-2008   #10 (permalink)
Ken Blake, MVP
On Tue, 1 Jan 2008 11:56:00 -0800, gavtheunchav
> laptop.. Thanks Gav
No, if it's just the drive that's died, you don't need a new laptop.
The drive can be replaced, usually very easily. A new drive costs
*much* less than a new laptop.
Operating System not found General Discussion
operating system not found General Discussion
Hlp:Operating system not found Vista installation & setup
Operating System Not Found General Discussion
operating system not found without Vista DVD Vista installation & setup
