Vista - Xp to Vista sharing problem
Old 01-02-2008   #1 (permalink)
Mike C
I have read through all the items I could find on here, but none of
the items worked or were applicable.
I have 2 computers networked that can see each other. One is Vista the
other XP. I have no problem accessing XP shares from the Vista
machine. When I try to access shares on the Vista machine from XP, I
can't. When I click on the workgroup, I see the machine. When I
double click it, it asks for a username and password. If I type the
the only username on the Vista machine (which has no password set), it
fails. It seems with having password protected sharing OFF, I
shouldn't get a prompt.
My setup:
On Vista
-Network discovery ON
-File sharing ON
-Password protected sharing OFF
-Public sharing OFF
-C drive is shared to Everyone
Thanks
Old 01-02-2008   #2 (permalink)
Mike C
Re: Xp to Vista sharing problem
Quote:
> > My setup:
Quote:
> > On Vista
> > -File sharing ON
> > -Public sharing OFF
> Turn the password-protected sharing ON and create a user
> account/password on the Vista machine that matches the one on the XP box.
> If you wish the machine to boot directly to the Desktop (into one
> particular user's account) for convenience, you can do this. The
> instructions at this link work for both XP and Vista:
> Configure Windows to Automatically Login (MVP Ramesh) -http://windowsxp.mvps.org/Autologon.htm
> Malke
> Elephant Boy Computerswww.elephantboycomputers.com
> "Don't Panic!"
> MS-MVP Windows - Shell/User
Thanks-that works. It is a hassle. I have 3 computers and had to
create the same account/pwd on all of them. I mean, if you select No
password sharing it is supposed to eliminate that! Why doesn't it?
Does it only work between Vista machines?
Old 01-02-2008   #3 (permalink)
Malke
I really don't think creating matching user accounts/passwords on only
three computers is an onerous task. If you had 10 of them it might be,
but at that point you should be considering a server anyway.
When you use the "password off" feature, you're connecting as Guest
(which has its own security risks and limitations so isn't recommended).
I note that you didn't mention the version of XP you're using. If it is
XP Pro, enable Simple File Sharing (Folder Options>View tab) and then
you can connect as Guest.
Malke
"Don't Panic!"
Old 01-02-2008   #4 (permalink)
Andre Da Costa[ActiveWin]
But it was quite obvious as noted in my post, just turn 'Password Protected
Sharing On'.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"Mike C" <michaeljc70@xxxxxx> wrote in message
news:0b102626-0b64-4e32-a742-1e9159c06406@xxxxxx
>> Malke
>> "Don't Panic!"
> I guess you are right creating 3 accounts isn't that hard, but the
> hours I spent trying to figure it out was. My point is it shouldn't
> be that hard to share files on a home version of a product......I am a
> developer and not a computer novice.
Old 01-03-2008   #5 (permalink)
Mike C
On Jan 2, 1:19 pm, "Andre Da Costa[ActiveWin]" <andre...@xxxxxx>
wrote:
> Sharing On'.
> Andre
> Blog:http://adacosta.spaces.live.com
> My Vista Quickstart Guide:http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry"Mike C" <michaelj...@xxxxxx> wrote in message
Quote:
Quote:
> >> Malke
> >> "Don't Panic!"
It very clearly states that if you turn password sharing off, you
don't need accounts right there in the control panel! Clearly that
isn't the case.
XP to Vista sharing problem Vista networking & sharing
a new problem with XP and Vista sharing. Vista networking & sharing
Problem Sharing Between XP and Vista Vista networking & sharing
ANOTHER vista - xp sharing problem Vista networking & sharing
Another XP and Vista Sharing Problem Vista networking & sharing
