| | Help - Mouse pointer freezes screen, locks up system I'm running XP Pro on my main computer and recently installed Visa Ultimate on a separate HD. Vista works just fine and so far I'm impressed with this new OS except for the following problem: Every so often the mouse pointer will just freeze and I cannot do anything except hold in the power button until the computer shuts down. Although the problem has happened once or twice while I was moving through normal dialog boxes, it will almost always happen while playing solitaire. Very frustrating, you just never know when the system will lock up. The only program installed on Vista is Microsoft Office 2003. I've upgraded the graphic driver to one that supports Vista and tried a different mouse - no help. Any and all suggestions greatly appreciated. Jim |
| | Re: Help - Mouse pointer freezes screen, locks up system That really sounds like a driver of some kind. Sometimes a newer driver is not the answer, sometimes it is. In some case's, an older driver will work better. If the machine freezes in XP or Vista, I'd suspect a hardware issue. Have you checked event viewer to see if it recorded the freeze and what caused it? -- A Professional Amateur...If anyone knew it all, none of would be here! CarGodZeroOne@xxxxxx Change Alpha to Numeric to reply "Jim" <jrwolfe@xxxxxx> wrote in message news:%23whUo4aTIHA.5980@xxxxxx Quote: > I'm running XP Pro on my main computer and recently installed Visa > Ultimate on a separate HD. Vista works just fine and so far I'm impressed > with this new OS except for the following problem: > > > > Every so often the mouse pointer will just freeze and I cannot do anything > except hold in the power button until the computer shuts down. Although > the problem has happened once or twice while I was moving through normal > dialog boxes, it will almost always happen while playing solitaire. Very > frustrating, you just never know when the system will lock up. > > > > The only program installed on Vista is Microsoft Office 2003. I've > upgraded the graphic driver to one that supports Vista and tried a > different mouse - no help. > > > > Any and all suggestions greatly appreciated. > > > Jim > > |
| | Re: Help - Mouse pointer freezes screen, locks up system Thank you for the advice, will look at another possible driver. I'm not very knowledge about the Event Viewer but I did see this statement: "ACPI BIOS does not contain an IRQ for the device in PCI slot 14, function 0" Jim "Not Me" <cargodZeroOne@xxxxxx> wrote in message news:uK87oCbTIHA.6036@xxxxxx Quote: > That really sounds like a driver of some kind. > Sometimes a newer driver is not the answer, sometimes it is. > In some case's, an older driver will work better. > If the machine freezes in XP or Vista, I'd suspect a hardware issue. > Have you checked event viewer to see if it recorded the freeze and what > caused it? > > -- > A Professional Amateur...If anyone knew it all, none of would be here! > CarGodZeroOne@xxxxxx > Change Alpha to Numeric to reply > "Jim" <jrwolfe@xxxxxx> wrote in message > news:%23whUo4aTIHA.5980@xxxxxx Quote: >> I'm running XP Pro on my main computer and recently installed Visa >> Ultimate on a separate HD. Vista works just fine and so far I'm impressed >> with this new OS except for the following problem: >> >> >> >> Every so often the mouse pointer will just freeze and I cannot do >> anything except hold in the power button until the computer shuts down. >> Although the problem has happened once or twice while I was moving >> through normal dialog boxes, it will almost always happen while playing >> solitaire. Very frustrating, you just never know when the system will >> lock up. >> >> >> >> The only program installed on Vista is Microsoft Office 2003. I've >> upgraded the graphic driver to one that supports Vista and tried a >> different mouse - no help. >> >> >> >> Any and all suggestions greatly appreciated. >> >> >> Jim >> >> > |
| | Re: Help - Mouse pointer freezes screen, locks up system That error is probably nothing to do with your problem. What is in the text below is an excerpt from http://support.microsoft.com/kb/930062/en-us Error message is logged in the System log every time that you start Windows Vista: "ACPI BIOS does not contain an IRQ for the device in PCI slot <number>" SYMPTOMS An error message that resembles the following may be logged in the System log every time that you start a Windows Vista-based computer: Event Type: Error Event Source: ACPI Event Category: None Event ID: 6 Date: Date Time: Time User: N/A Computer: Computer_Name Description: IRQARB: ACPI BIOS does not contain an IRQ for the device in PCI slot number, function number. Please contact your system vendor for technical assistance. CAUSE This error message may occur on a computer that uses a Peripheral Component Interconnect (PCI) bridge that supports message-signaled interrupts but does not support line-based interrupts. RESOLUTION This error message may safely be ignored. "Jim" <jrwolfe@xxxxxx> wrote in message news:OGSWL7fTIHA.5164@xxxxxx Quote: > Thank you for the advice, will look at another possible driver. I'm not > very knowledge about the Event Viewer but I did see this statement: > > "ACPI BIOS does not contain an IRQ for the device in PCI slot 14, function > 0" > > Jim > > "Not Me" <cargodZeroOne@xxxxxx> wrote in message > news:uK87oCbTIHA.6036@xxxxxx Quote: >> That really sounds like a driver of some kind. >> Sometimes a newer driver is not the answer, sometimes it is. >> In some case's, an older driver will work better. >> If the machine freezes in XP or Vista, I'd suspect a hardware issue. >> Have you checked event viewer to see if it recorded the freeze and what >> caused it? >> >> -- >> A Professional Amateur...If anyone knew it all, none of would be here! >> CarGodZeroOne@xxxxxx >> Change Alpha to Numeric to reply >> "Jim" <jrwolfe@xxxxxx> wrote in message >> news:%23whUo4aTIHA.5980@xxxxxx Quote: >>> I'm running XP Pro on my main computer and recently installed Visa >>> Ultimate on a separate HD. Vista works just fine and so far I'm >>> impressed with this new OS except for the following problem: >>> >>> >>> >>> Every so often the mouse pointer will just freeze and I cannot do >>> anything except hold in the power button until the computer shuts down. >>> Although the problem has happened once or twice while I was moving >>> through normal dialog boxes, it will almost always happen while playing >>> solitaire. Very frustrating, you just never know when the system will >>> lock up. >>> >>> >>> >>> The only program installed on Vista is Microsoft Office 2003. I've >>> upgraded the graphic driver to one that supports Vista and tried a >>> different mouse - no help. >>> >>> >>> >>> Any and all suggestions greatly appreciated. >>> >>> >>> Jim >>> >>> >> > > |
| | Re: Help - Mouse pointer freezes screen, locks up system "Jim" <jrwolfe@xxxxxx> wrote in news:OGSWL7fTIHA.5164@xxxxxx: Quote: > Thank you for the advice, will look at another possible driver. I'm > not very knowledge about the Event Viewer but I did see this > statement: > > "ACPI BIOS does not contain an IRQ for the device in PCI slot 14, > function 0" > > Jim > > "Not Me" <cargodZeroOne@xxxxxx> wrote in message > news:uK87oCbTIHA.6036@xxxxxx Quote: Quote: >> A Professional Amateur...If anyone knew it all, none of would be >> here! CarGodZeroOne@xxxxxx >> Change Alpha to Numeric to reply >> "Jim" <jrwolfe@xxxxxx> wrote in message >> news:%23whUo4aTIHA.5980@xxxxxx Quote: >>> I'm running XP Pro on my main computer and recently installed Visa >>> Ultimate on a separate HD. Vista works just fine and so far I'm >>> impressed with this new OS except for the following problem: >>> >>> >>> >>> Every so often the mouse pointer will just freeze and I cannot do >>> anything except hold in the power button until the computer shuts >>> down. Although the problem has happened once or twice while I was >>> moving through normal dialog boxes, it will almost always happen >>> while playing solitaire. Very frustrating, you just never know when >>> the system will lock up. >>> >>> >>> >>> The only program installed on Vista is Microsoft Office 2003. I've >>> upgraded the graphic driver to one that supports Vista and tried a >>> different mouse - no help. >>> >>> >>> >>> Any and all suggestions greatly appreciated. >>> >>> >>> Jim my D-Link wireless card in a PCI slot and disabled the MB wireless. I kept having the freezing problem until I removed the D-Link card and used the onboard wireless. If you have a MB with onboard wireless, that may be the problem. As the person who answered your post siad, the IRQ notice meant nothing. bdog |
| Can Not See Mouse Pointer on Screen | Vista hardware & devices | |||
| Mouse pointer dissapearing during full screen games | Gaming | |||
| Black Screen with mouse pointer during boot | General Discussion | |||
| Mouse pointer resets after system restart. | General Discussion | |||
| mouse pointer sticks to top left corner of screen | General Discussion | |||
