| | how to manually index? i know its already on in the background but its slow cause of user activity. is there anyway i can manully start indexing when i can afford to leave my system idle. |
| | Re: how to manually index? I don't know about doing that, but I turned indexing off on all my drives since I almost never search for things using search anyway - I always just open the folder I need and pull up the file. if you don't use search, there is no reason I see for leaving indexing on. And from what I understand, indexing just speeds up searching anyway - doesn't disable it. Lori "Neerav" <k.neerav@xxxxxx> wrote in message news:3C134636-7692-4EBB-B412-263DC4C56714@xxxxxx Quote: > i know its already on in the background but its slow cause of user > activity. is there anyway i can manully start indexing when i can afford > to leave my system idle. |
| | Re: how to manually index? If you leave your PC for a couple days to index the drive, the performance will eventually get back to normal. I would leave it on to be honest with you. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "Neerav" <k.neerav@xxxxxx> wrote in message news:3C134636-7692-4EBB-B412-263DC4C56714@xxxxxx Quote: >i know its already on in the background but its slow cause of user >activity. is there anyway i can manully start indexing when i can afford to >leave my system idle. |
| | Re: how to manually index? "couple of days" was that satire? Neerav "Andre Da Costa[ActiveWin]" <andred25@xxxxxx> wrote in message news:eO6GIvhTIHA.3516@xxxxxx Quote: > If you leave your PC for a couple days to index the drive, the performance > will eventually get back to normal. I would leave it on to be honest with > you. > -- > Andre > Blog: http://adacosta.spaces.live.com > My Vista Quickstart Guide: > http://adacosta.spaces.live.com/blog...3DB!9709.entry > "Neerav" <k.neerav@xxxxxx> wrote in message > news:3C134636-7692-4EBB-B412-263DC4C56714@xxxxxx Quote: >>i know its already on in the background but its slow cause of user >>activity. is there anyway i can manully start indexing when i can afford >>to leave my system idle. > |
| | Re: how to manually index? Well, you have to understand, if you have thousands of files, it will not index everything in the blink of an eye. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "Neerav" <k.neerav@xxxxxx> wrote in message news:77815EC1-2880-4C11-8D18-E68E7F5487BD@xxxxxx Quote: > "couple of days" > was that satire? > > Neerav > > "Andre Da Costa[ActiveWin]" <andred25@xxxxxx> wrote in message > news:eO6GIvhTIHA.3516@xxxxxx Quote: >> If you leave your PC for a couple days to index the drive, the >> performance will eventually get back to normal. I would leave it on to be >> honest with you. >> -- >> Andre >> Blog: http://adacosta.spaces.live.com >> My Vista Quickstart Guide: >> http://adacosta.spaces.live.com/blog...3DB!9709.entry >> "Neerav" <k.neerav@xxxxxx> wrote in message >> news:3C134636-7692-4EBB-B412-263DC4C56714@xxxxxx Quote: >>>i know its already on in the background but its slow cause of user >>>activity. is there anyway i can manully start indexing when i can afford >>>to leave my system idle. >> |
| | #6 (permalink) |
| | Re: how to manually index? "Neerav" <k.neerav@xxxxxx> wrote in message news:77815EC1-2880-4C11-8D18-E68E7F5487BD@xxxxxx Quote: > "couple of days" > was that satire? > It should be 'satire' for 'no more than half an hour'. The view that it takes a 'couple of days' is an uncorrected fallacy that's been perpertrating this group since its outset. -- Jon |
| | #7 (permalink) |
| | Re: how to manually index? offcourse not. i said i'm ready to leave my computer idle for sometime. say like an hour. Neerav "Andre Da Costa[ActiveWin]" <andred25@xxxxxx> wrote in message news:OVIsqfiTIHA.6036@xxxxxx Quote: > Well, you have to understand, if you have thousands of files, it will not > index everything in the blink of an eye. > -- > Andre > Blog: http://adacosta.spaces.live.com > My Vista Quickstart Guide: > http://adacosta.spaces.live.com/blog...3DB!9709.entry > "Neerav" <k.neerav@xxxxxx> wrote in message > news:77815EC1-2880-4C11-8D18-E68E7F5487BD@xxxxxx Quote: >> "couple of days" >> was that satire? >> >> Neerav >> >> "Andre Da Costa[ActiveWin]" <andred25@xxxxxx> wrote in message >> news:eO6GIvhTIHA.3516@xxxxxx Quote: >>> If you leave your PC for a couple days to index the drive, the >>> performance will eventually get back to normal. I would leave it on to >>> be honest with you. >>> -- >>> Andre >>> Blog: http://adacosta.spaces.live.com >>> My Vista Quickstart Guide: >>> http://adacosta.spaces.live.com/blog...3DB!9709.entry >>> "Neerav" <k.neerav@xxxxxx> wrote in message >>> news:3C134636-7692-4EBB-B412-263DC4C56714@xxxxxx >>>>i know its already on in the background but its slow cause of user >>>>activity. is there anyway i can manully start indexing when i can afford >>>>to leave my system idle. >>> >>> > |
| | #8 (permalink) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: how to manually index? This will show you how to enable or disable the Index. You may find that you like it disabled. This way all of your searches will be ran using the non-indexed search, and will be accurate. Index - Enable or Disable Shawn |
| changing the IRQ manually | Vista General | |||
| Should I install SP1 manually? | Vista General | |||
| remove items from index manually | Vista file management | |||
| why manually redirect to system32? | Drivers | |||
| help. How to remove rc2 manually | PowerShell | |||
