Vista - Vista IE Problem restart
Old 01-03-2008   #1 (permalink)
Lee
Hi Im not sure if this is the active x controll issue with some bank
overseas but...
When i load up IE in Vista/Retail, everything is fine but when i close the
IE window I get the message "IE has encountered a problem, searching for a
fix" after about 30sec it goes to "windows wil resart" All im trying to do
is close the browser window. Anyone have a fix for this.Thanks Cheers
RayLee
IT/Parts/Warranty/Service
800-467-3905
314-894-1814 fx
www.vancityrv.com
www.mobilervtech.com
www.myrvspace.com
Old 01-03-2008   #2 (permalink)
Re: Vista IE Problem restart
Quote  Quote: Originally Posted by Lee View Post
overseas but...
RayLee
800-467-3905
314-894-1814 fx
VanCityRV vancamper rv classb motorhome - Roadtrek, Pleasure-Way, Leisurevans, Winnebago-era, vista cruiser, Sprinterrv
The Worlds Largest Camping Resource - myRVspace.com
Hi Lee,
It could be a IE7 add-on causing the problem. This will show you how to test and fix the problem if it is.
Internet Explorer - Reset
Old 01-03-2008   #3 (permalink)
Andre Da Costa[ActiveWin]
Sounds like a bad plug in possibly, in IE, click Tools > Manage Add-Ons >
Enable or Disable Add-ons
Look for any suspicious add ons you suspect might be triggering this crash,
otherwise, reset Internet Explorer's settings, Click Tools > Options >
Advanced (tab) > under 'Reset Internet Explorer settings' > click 'Reset'.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"Lee" <vancityrvservice@xxxxxx> wrote in message
news:ujI3AgjTIHA.4880@xxxxxx
> overseas but...
> RayLee
> 800-467-3905
> 314-894-1814 fx
> www.vancityrv.com
> www.myrvspace.com
Please Help: Vista Restart Problem General Discussion
Restart problem when installing vista ultimate Vista installation & setup
Shutdown / Restart Problem Vista 64 Vista General
Problem with restart messages on Vista load Vista performance & maintenance
Restart problem! Vista performance & maintenance
