| | How do I customize the view of my C drive? All of a sudden the view of the C drive in Explorer is assuming all the sub-folders are photos. If it were any other folder, I could right click on the folder and select properties/customize/all items. When one right clicks on the C: drive folder this option is not offered. How do I change it back to the default view and why did it decide to switch to photo view? thanks |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: How do I customize the view of my C drive? All of a sudden the view of the C drive in Explorer is assuming all the sub-folders are photos. If it were any other folder, I could right click on the folder and select properties/customize/all items. When one right clicks on the C: drive folder this option is not offered. How do I change it back to the default view and why did it decide to switch to photo view? thanks This will show you how to change it back to the "All Items" template. See the NOTE under step one for how. Windows Explorer - Folder Type Templates Shawn |
| | Re: How do I customize the view of my C drive? In article <brink.32ot43@xxxxxx-mx.forums.net>, brink.32ot43@xxxxxx-mx.forums.net says... Quote: > > SwampYankee;562067 Wrote: Quote: > > All of a sudden the view of the C drive in Explorer is assuming all the > > sub-folders are > > photos. If it were any other folder, I could right click on the folder > > and select > > properties/customize/all items. When one right clicks on the C: drive > > folder this option is > > not offered. How do I change it back to the default view and why did it > > decide to switch to > > photo view? > > thanks > Hi SwampYankee, > > This will show you how to change it back to the "All Items" template. > See the NOTE under step one for how. > > Windows Explorer - Folder Type Templates > > Shawn > > > my view back to the way it was before. If I want to read through all those pages and links I might as well install XP again. Anybody have a solution to this? Why was the layout changed in the first place? Why do I have to go through all these gyrations I just want to have explorer show my hard drive as a series of files! Not a bunch of photos!!!! How do I make Vista display my C: drive as a series of folders and files? Not a bunch of photos? It really is a computer with files on it not a camera! help........................pleass..... |
| | Re: How do I customize the view of my C drive? Click Views. Make your choice. -- Regards, Richard Urban Microsoft MVP Windows Shell/User "SwampYankee" <1@xxxxxx> wrote in message news:MPG.21ea1e47c78d6be19896a9@xxxxxx Quote: > In article <brink.32ot43@xxxxxx-mx.forums.net>, brink.32ot43@xxxxxx-mx.forums.net > says... Quote: >> >> SwampYankee;562067 Wrote: Quote: >> > All of a sudden the view of the C drive in Explorer is assuming all the >> > sub-folders are >> > photos. If it were any other folder, I could right click on the folder >> > and select >> > properties/customize/all items. When one right clicks on the C: drive >> > folder this option is >> > not offered. How do I change it back to the default view and why did it >> > decide to switch to >> > photo view? >> > thanks >> Hi SwampYankee, >> >> This will show you how to change it back to the "All Items" template. >> See the NOTE under step one for how. >> >> Windows Explorer - Folder Type Templates >> >> Shawn >> >> >> > to know how to turn > my view back to the way it was before. If I want to read through all > those pages and links I > might as well install XP again. Anybody have a solution to this? Why was > the layout changed > in the first place? Why do I have to go through all these gyrations I > just want to have > explorer show my hard drive as a series of files! Not a bunch of > photos!!!! How do I make > Vista display my C: drive as a series of folders and files? Not a bunch > of photos? It > really is a computer with files on it not a camera! > help........................pleass..... |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: How do I customize the view of my C drive? In article <brink.32ot43@xxxxxx-mx.forums.net>, brink.32ot43@xxxxxx-mx.forums.net says... Quote: > > SwampYankee;562067 Wrote: > > Hi SwampYankee, > > This will show you how to change it back to the "All Items" template. > See the NOTE under step one for how. > > Windows Explorer - Folder Type Templates > > Shawn > > > my view back to the way it was before. If I want to read through all those pages and links I might as well install XP again. Anybody have a solution to this? Why was the layout changed in the first place? Why do I have to go through all these gyrations I just want to have explorer show my hard drive as a series of files! Not a bunch of photos!!!! How do I make Vista display my C: drive as a series of folders and files? Not a bunch of photos? It really is a computer with files on it not a camera! help........................pleass..... If you want to restore the View (folder template) back to the way it was (All Items) for your C:\ drive, then the NOTE under step 1 will show you how to do it. Windows Explorer - Folder Type Templates Shawn |
| | #6 (permalink) |
| | Re: How do I customize the view of my C drive? In article <uEvf23BUIHA.4440@xxxxxx>, richardurbanREMOVETHIS@xxxxxx says... Quote: > Click Views. > > Make your choice. > > icon size. It still treats the whole C drive and its sub folders as photo images. So it lists each folder, but the column headers for the entire c drive are: Name, Date Taken, Tags Size and Rating. I want the folders, date and size like in the old explorer thanks |
| Customize selected view options - Color option has disappeared | Live Mail | |||
| Services - Customize View of Window | Tutorials | |||
| Customize Folders at drive level. | Vista General | |||
| Need to customize shell view for existing mount point | PowerShell | |||
| Customize View in Device Manager | Vista General | |||
