Vista - icon problems
Old 01-06-2008   #1 (permalink)
missmo
icon problems
I keep changing my desktop icons using the property tab and when I go to the
place I click on and return to the desktop, the icon I chose has been
replaced by another icon. This is happening to several icons I have tried to
permanently change. This is a new problem I am having. It is driving me
crazy! Does anyone have a quick fix for me? I am needing something simple to
try please!!
Old 01-06-2008   #2 (permalink)
Re: icon problems
Quote  Quote: Originally Posted by missmo View Post
try please!!
Hi Missmo,
If you do not need to makes changes to the file often, you can set the file as read-only after you changed the icon. Just unset red-only when you need to make a change to it. This may lock in the icon for you.
Read-only File and Folder Attribute
Big vista problems need help icon/background/graphics/personalise problems Vista performance & maintenance
icon problems General Discussion
Icon problems after moving from XP Vista General
To all with shortcut icon problems Vista General
RE: Network Icon Problems Vista networking & sharing
