| | Audio Hi I m having one HP laptop with vista.It gives the message" YOUR COMPUTER DOES NOT HAVE THE REQUIRED AUDIO COMPRESSION FORMAT" .Can any one help please? |
| | Re: Audio /Selvakumar/ said: Quote: > I m having one HP laptop with vista. It gives the message" YOUR COMPUTER > DOES NOT HAVE THE REQUIRED AUDIO COMPRESSION FORMAT." > Can any one help please? someone may be able to recommend a codec that will enable it to be played. In lieu of that, there are code packs available for free via the Net. One popular package is K-Lite. Try the STANDARD version. If it does nothing to help, it can be uninstalled. http://www.free-codecs.com/K_Lite_Co...k_download.htm |
| | Re: Audio Most codec packs foul up systems. Here's a list of problems I personally verified: * http://zachd.com/pss/pss.html#divx It's possible I'm missing some or missing some new/old problems - that's just a starting point, and explains why codec packs are so frightening and generally bad. -- Speaking for myself only. See http://zachd.com/pss/pss.html for some helpful WMP info. This posting is provided "AS IS" with no warranties, and confers no rights. -- <dev@xxxxxx> wrote in message news:etWdJnUUIHA.2000@xxxxxx Quote: > /Selvakumar/ said: > Quote: >> I m having one HP laptop with vista. It gives the message" YOUR COMPUTER >> DOES NOT HAVE THE REQUIRED AUDIO COMPRESSION FORMAT." >> Can any one help please? > If you state exactly what type of audio file you are attempting to play, > someone may be able to recommend a codec that will enable it to be played. > > In lieu of that, there are code packs available for free via the Net. > One popular package is K-Lite. Try the > STANDARD version. If it does nothing to help, it can be uninstalled. > > http://www.free-codecs.com/K_Lite_Co...k_download.htm |
| | Re: Audio /Selvakumar/ said: Quote: Quote: > > I m having one HP laptop with vista. It gives the message" YOUR Quote: Quote: > > DOES NOT HAVE THE REQUIRED AUDIO COMPRESSION FORMAT." > > Can any one help please? someone may be able to recommend a codec that will enable it to be played. In lieu of that, there are code packs available for free via the Net. One popular package is K-Lite. Try the STANDARD version. If it does nothing to help, it can be uninstalled. http://www.free-codecs.com/K_Lite_Co...k_download.htm |
| | Re: Audio Dear sir, Thanks for ur response. I face this audio problem when using yahoo messenger for chatting with friends. with best rgs, selvakumat "dev@xxxxxx" wrote: Quote: > /Selvakumar/ said: > Quote: > > I m having one HP laptop with vista. It gives the message" YOUR COMPUTER > > DOES NOT HAVE THE REQUIRED AUDIO COMPRESSION FORMAT." > > Can any one help please? > If you state exactly what type of audio file you are attempting to play, > someone may be able to recommend a codec that will enable it to be played. > > In lieu of that, there are code packs available for free via the Net. > One popular package is K-Lite. Try the > STANDARD version. If it does nothing to help, it can be uninstalled. > > http://www.free-codecs.com/K_Lite_Co...k_download.htm > |
| How do I get audio file format in audio filter driver? | Vista music pictures video | |||
| Audio drivers for Intel Sigmatel onboard audio | Vista hardware & devices | |||
| If you have a HP Laptop and No Audio Drivers/Audio Problems | Vista hardware & devices | |||
| Realtek AC'97 audio driver provided by Microsoft. Audio error MCE | Vista hardware & devices | |||
| Vista Beta 2 - Audio / Sound Drivers - Universal Audio Architectur | Vista hardware & devices | |||
