| | using MMC to remote administrating another PC there are 2 PCs running Vista ultimate 32bit when I try to use MMC on either PC to remote connect to the other one, it says access denied two PCs have the identical Account setting ( acct name and password, and they are in administrators) configured inbound rule for the PC recieving connection in firewall is it the UAC thing preventing me to doing the job? |
| | Re: using MMC to remote administrating another PC "Andrew" <hah@xxxxxx> wrote in message news:%23PHuKCbUIHA.5508@xxxxxx Quote: > there are 2 PCs running Vista ultimate 32bit > > when I try to use MMC on either PC to remote connect to the other one, it > says access denied > > two PCs have the identical Account setting ( acct name and password, and > they are in administrators) > > configured inbound rule for the PC recieving connection in firewall > > is it the UAC thing preventing me to doing the job? > > Sounds more like a credentials issue, than a UAC one. Try it using the built-in admin's credentials, rather than those of an 'administrator' account. -- Jon |
| | Re: using MMC to remote administrating another PC You may have to make this registry change. http://www.jimmah.com/vista/Administ...ltertoken.aspx Be sure to create a System Restore point before doing this. Editing the registry could cause problems. -- Kerry Brown Microsoft MVP - Shell/User http://www.vistahelp.ca/phpBB2/ "Andrew" <hah@xxxxxx> wrote in message news:%23PHuKCbUIHA.5508@xxxxxx Quote: > there are 2 PCs running Vista ultimate 32bit > > when I try to use MMC on either PC to remote connect to the other one, it > says access denied > > two PCs have the identical Account setting ( acct name and password, and > they are in administrators) > > configured inbound rule for the PC recieving connection in firewall > > is it the UAC thing preventing me to doing the job? > > |
| Remote Assistance + video (or animated gifs) on the remote screen | Vista General | |||
| How to view remote certificates installed on remote machine? | PowerShell | |||
| checked for logged on user on remote machine + remote reboot | PowerShell | |||
| Remote administrating Firewall setting between Vista | Vista security | |||
| Can't login to remote comp. using Remote Desktop Connection on Vis | Vista account administration | |||
