| | System Stuck in Loop on Both Reboot and System Restore Yesterday I tried to install Visual Basic Express 2008. After the installation completed a reboot was required. During that reboot the computer got stuck in the configuring updates/restart loop mentioned in many other posts. I also tried to reboot into Safe Mode and via Last Known Good Configuration but neither worked as the system went back into the reboot mode. After hours of seeing if it would resolve itself I tried a system restore. That process allows me to pick a restore point (I have tried several) and it proceeds until the point where the "Finalizing file restore" message and progress bar appears. Now it is stuck there, continuing the finalizing process but never finishing. I have tried to reinstall Vista using my serial number but it will not let me install as an upgrade as it requires me to run it inside of Windows which I can not access. If I try to run it without the serial number, it only allows a custom install which will overwrite my files. Any ideas how to solve this problem? Thanks. |
| System restore points deleted on reboot | Vista General | |||
| Stuck in the "Updates 3 of 3" Reboot Loop after Service Pack 1 | Vista General | |||
system restore update configuration loop | General Discussion | |||
| System restore stuck | Vista performance & maintenance | |||
| System Restore Stuck at "Finalizing file restore" | Vista General | |||
