| | Re: Posts not appearing through WLM "darksentinel" <darksentinel@xxxxxx> wrote in message news:Oq3mwC#TIHA.4740@xxxxxx Quote: > darksentinel wrote: Quote: >> Seems like none of my stuff has been hitting since Jan. 1. When I post to >> the test it group, it appears fine, but not to THIS group. Using >> Thunderbird to see if that works. Anyone else having this problem? > Ok....seems to be a WLM issue. Works in T-Bird. full uninstall, and then re-install. Told him that I was running Vista. What does he send me? Removal instructions for XP. Luckily I halfway know what I am doing. So keeping my fingers crossed to see if this will post. -- Transformers!!! More than meets the eye! http://www.lockergnome.com/darksentinel Undo the munge to reply by email |
| | Re: Posts not appearing through WLM YAY!!!! It's fixed!!! -- Transformers!!! More than meets the eye! http://www.lockergnome.com/darksentinel Undo the munge to reply by email |
| | Re: Posts not appearing through WLM "DarkSentinel" <darkmungesentinel@xxxxxx> wrote in message news:34CC4C81-727B-4C6A-A7A6-4ABC825089A8@xxxxxx Quote: > YAY!!!! It's fixed!!! ![]() -- Transformers!!! More than meets the eye! http://www.lockergnome.com/darksentinel Undo the munge to reply by email |
| Posts not appearing | Vista mail | |||
| NG posts not appearing in my WM client | Vista mail | |||
| My Posts Not Appearing in Windows Mail | Vista mail | |||
| Posts not appearing on vista general | Vista security | |||
