| Guest | Recycle Bin - look does not toggle between full and empty I had erroneously deleted and then reinstated Recycle Bin by going into the Control Plan -> Personalization, etc... But, NOW, the Recycle Bin ICON on the desktop always show as the empty ICON and not the filled ICON (although it does have files, and I can open the folder and see what is in there, and everything is there that is supposed to be).. How do I fix this so that the toggling of Recycle Icons is reinstated? If I right click on the icon, there is no suitable option to do this... Thanks in advance. |
| Administrator | Re: Recycle Bin - look does not toggle between full and empty I had erroneously deleted and then reinstated Recycle Bin by going into the Control Plan -> Personalization, etc... But, NOW, the Recycle Bin ICON on the desktop always show as the empty ICON and not the filled ICON (although it does have files, and I can open the folder and see what is in there, and everything is there that is supposed to be).. How do I fix this so that the toggling of Recycle Icons is reinstated? If I right click on the icon, there is no suitable option to do this... Thanks in advance. This will show you how to fix your refreshing problem with the Recycle Bin. Recycle Bin Shawn |
| Guest | Re: Recycle Bin - look does not toggle between full and empty Recycle Bin icon does not refresh automatically: http://www.winhelponline.com/article...matically.html -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "SKM" <SKM@xxxxxx> wrote in message news:E267559A-6E62-49F4-8218-0896143F9AAB@xxxxxx Quote: >I had erroneously deleted and then reinstated Recycle Bin by going into >the > Control Plan -> Personalization, etc... > > But, NOW, the Recycle Bin ICON on the desktop always show as the empty > ICON > and not the filled ICON (although it does have files, and I can open the > folder and see what is in there, and everything is there that is supposed > to > be).. > > How do I fix this so that the toggling of Recycle Icons is reinstated? If > I > right click on the icon, there is no suitable option to do this... > > Thanks in advance. |
| Guest | Re: Recycle Bin - look does not toggle between full and empty Thank you Andre.. Your response - Option 2 - worked best and was most succinct. Thank you brink .. Your response helped me understand what the steps achieved. It appears that we are just fooling the system to force re-set.. i.e., not only is this (dumb) system allowing accidentally deleting Recycle Bin [whatever for], when we reset it, it is not doing full reset! Alas! Only MS!! Now why would this not be in high priority when it has obviously caused so many people to complain about the issue of deleted Recycle Bin? Andre and brink, I have saved both of your answer links for future reference as I know I am bound to delete Recycle Bin again and this seems to be the way to restore full functionality of the Recycle Bin. Thank you. "Andre Da Costa[ActiveWin]" wrote: Quote: > Recycle Bin icon does not refresh automatically: > http://www.winhelponline.com/article...matically.html > -- > Andre > Blog: http://adacosta.spaces.live.com > My Vista Quickstart Guide: > http://adacosta.spaces.live.com/blog...3DB!9709.entry > "SKM" <SKM@xxxxxx> wrote in message > news:E267559A-6E62-49F4-8218-0896143F9AAB@xxxxxx Quote: > >I had erroneously deleted and then reinstated Recycle Bin by going into > >the > > Control Plan -> Personalization, etc... > > > > But, NOW, the Recycle Bin ICON on the desktop always show as the empty > > ICON > > and not the filled ICON (although it does have files, and I can open the > > folder and see what is in there, and everything is there that is supposed > > to > > be).. > > > > How do I fix this so that the toggling of Recycle Icons is reinstated? If > > I > > right click on the icon, there is no suitable option to do this... > > > > Thanks in advance. > > |
| Administrator | Re: Recycle Bin - look does not toggle between full and empty Thank you Andre.. Your response - Option 2 - worked best and was most succinct. Thank you brink .. Your response helped me understand what the steps achieved. It appears that we are just fooling the system to force re-set.. i.e., not only is this (dumb) system allowing accidentally deleting Recycle Bin [whatever for], when we reset it, it is not doing full reset! Alas! Only MS!! Now why would this not be in high priority when it has obviously caused so many people to complain about the issue of deleted Recycle Bin? Andre and brink, I have saved both of your answer links for future reference as I know I am bound to delete Recycle Bin again and this seems to be the way to restore full functionality of the Recycle Bin. Thank you. "Andre Da Costa[ActiveWin]" wrote: Quote: > Recycle Bin icon does not refresh automatically: > Recycle Bin icon does not refresh automatically > -- > Andre > Blog: Teching It Easy: Windows Vista > My Vista Quickstart Guide: > Teching It Easy: Windows Vista: Windows Vista RTM FAQ and Quick Start Guide. > "SKM" <SKM@xxxxxx> wrote in message > news:E267559A-6E62-49F4-8218-0896143F9AAB@xxxxxx > Hi SKM, This will show you how to fix your refreshing problem with the Recycle Bin. Recycle Bin Shawn Glad to hear your problem is resolved. Thank you for the feedback. Shawn |
| empty recycle bin | PowerShell | |||
| CHANGE RECYCLE BIN ICON - EMPTY FULL HOW? | Vista General | |||
| I can't empty my recycle bin | Vista file management | |||
| Recycle bin icon not filling/emptying when recycle bin is full/emp | Vista General | |||
| Recycle Bin won't empty | Vista General | |||
