| Windows Vista Basic | Stupid Drivers... Need Help OMG I just clean installed XP Pro on my HP a5040a and there are no drivers for it. All of them are Vista. Any ideas on how to get them. The mobo is P5LP-LE. Help is appreciated. |
| | Re: Stupid Drivers... Need Help "toloratedmeat" <toloratedmeat.32ww3g@xxxxxx-mx.forums.net> wrote in message news:toloratedmeat.32ww3g@xxxxxx-mx.forums.net... Quote: > > OMG I just clean installed XP Pro on my HP a5040a and there are no > drivers for it. All of them are Vista. Any ideas on how to get them. The > mobo is P5LP-LE. Help is appreciated. > Did you check the mfg's website? They should have the drivers there |
| | Re: Stupid Drivers... Need Help Check the manufacturers website to find out if device drivers for Windows XP are available for that model computer. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "toloratedmeat" <toloratedmeat.32ww3g@xxxxxx-mx.forums.net> wrote in message news:toloratedmeat.32ww3g@xxxxxx-mx.forums.net... Quote: > > OMG I just clean installed XP Pro on my HP a5040a and there are no > drivers for it. All of them are Vista. Any ideas on how to get them. The > mobo is P5LP-LE. Help is appreciated. > > > -- > toloratedmeat |
| | RE: Stupid Drivers... Need Help Hi toloratedmeat, I have just checked the HP website and there are no other drivers available for your machine other than the Vista ones (both 32-bit and 64-bit). You could try contacting HP to see if they are going to develop XP drivers for your machine, but I don't hold out much hope. Dwarf "toloratedmeat" wrote: Quote: > > OMG I just clean installed XP Pro on my HP a5040a and there are no > drivers for it. All of them are Vista. Any ideas on how to get them. The > mobo is P5LP-LE. Help is appreciated. > > > -- > toloratedmeat > |
| | Re: Stupid Drivers... Need Help On Wed, 9 Jan 2008 03:00:23 -0600, toloratedmeat <toloratedmeat.32ww3g@xxxxxx-mx.forums.net> wrote: Quote: > > OMG I just clean installed XP Pro on my HP a5040a and there are no > drivers for it. All of them are Vista. Any ideas on how to get them. The > mobo is P5LP-LE. Help is appreciated. There may not be XP drivers available, and you may be out of luck. The assumption that every new computer that comes with Vista can run XP instead is not correct. If that's the case with your computer, your only choice will be to put Vista back on it. -- Ken Blake, Microsoft MVP Windows - Shell/User Please Reply to the Newsgroup |
| Stupid Me but now drivers wont load. | Drivers | |||
| I'm stupid.I can't help it! | General Discussion | |||
| HELP!! I am STUPID!! | Vista installation & setup | |||
| stupid, stupid Microsoft [MAC access control desperately needed!] | Vista General | |||
| stupid me help if you can | Vista General | |||
