| | Problems with installing updates KB943411 and KB935509 I'm running Vista Ultimate (x86) on a Dell laptop. I can't install the two critical updates KB943411 and KB935509. Have shut down firewall/AV and other unnecessary stuff. Also have tried installing them individually. No luck. Never had an update fail before and it's frustrating the hell out of me (and Vista has been doing for a couple of months, really). Anyone had any luck in getting these updates installed? Any advice? |
| Vista Home Premium 32 bit | Re: Problems with installing updates KB943411 and KB935509 I installed this update today on my Vostro 400 and didn't have a problem. |
| | RE: Problems with installing updates KB943411 and KB935509 For what it's worth I've the same problem. Using msconfig to start with all non-MS services and all startup apps disabled (including FW and AV) made no difference. Vista Ultimate (x86) on a custom PC with Intel 975X MB, SATA (AHIC, non-raid) HDs and Nvidia 8800 GT video. No hidden/uninstalled updates other than language packs. BitLocker pre-config tool installed but BitLocker not enabled. Has anyone encountered this and found a fix? The "I had no problems" voices aren't much help. Scott "Debbie.Croft@xxxxxx" wrote: Quote: > I'm running Vista Ultimate (x86) on a Dell laptop. I can't install the two > critical updates KB943411 and KB935509. Have shut down firewall/AV and other > unnecessary stuff. Also have tried installing them individually. No luck. > Never had an update fail before and it's frustrating the hell out of me (and > Vista has been doing for a couple of months, really). > > Anyone had any luck in getting these updates installed? Any advice? > > |
| | RE: Problems with installing updates KB943411 and KB935509 I have problems too. First all 7 latest updates failed. I noticed that KB905866 has different error code than other updates. I installed all other but KB905866 and then updating was successful. Then I tried to install KB905866 alone. But after several tries KB905866 failed every time to error 8000405. I have Vista Ultimate x64. Athlon X2 4200 and Radeon graphics. I make searching with Google and find some other people with same problems, but no solution yet. Someone think it is bitlocker. I don't understand whole Bitlocker at all. I never used it for nothing and I think I don't need it. Maybe i still have it in use somewhere in hidden? "smacmillan" wrote: Quote: > For what it's worth I've the same problem. Using msconfig to start with all > non-MS services and all startup apps disabled (including FW and AV) made no > difference. > > Vista Ultimate (x86) on a custom PC with Intel 975X MB, SATA (AHIC, > non-raid) HDs and Nvidia 8800 GT video. No hidden/uninstalled updates other > than language packs. BitLocker pre-config tool installed but BitLocker not > enabled. > > Has anyone encountered this and found a fix? The "I had no problems" voices > aren't much help. > > Scott > > "Debbie.Croft@xxxxxx" wrote: > Quote: > > I'm running Vista Ultimate (x86) on a Dell laptop. I can't install the two > > critical updates KB943411 and KB935509. Have shut down firewall/AV and other > > unnecessary stuff. Also have tried installing them individually. No luck. > > Never had an update fail before and it's frustrating the hell out of me (and > > Vista has been doing for a couple of months, really). > > > > Anyone had any luck in getting these updates installed? Any advice? > > > > |
| | RE: Problems with installing updates KB943411 and KB935509 Have exactely the same problem and is driving me crazy because I try to reinstall it a lot of time. My laptop is an Acer 7720G and I have windows Vista Ultimate in French. Thanks for response to fix the problem. "Jari N" wrote: Quote: > I have problems too. First all 7 latest updates failed. > I noticed that KB905866 has different error code than other updates. > I installed all other but KB905866 and then updating was successful. > Then I tried to install KB905866 alone. But after several tries KB905866 > failed every time to error 8000405. > > I have Vista Ultimate x64. Athlon X2 4200 and Radeon graphics. > > I make searching with Google and find some other people with same problems, > but no solution yet. Someone think it is bitlocker. I don't understand whole > Bitlocker at all. I never used it for nothing and I think I don't need it. > Maybe i still have it in use somewhere in hidden? > > > "smacmillan" wrote: > Quote: > > For what it's worth I've the same problem. Using msconfig to start with all > > non-MS services and all startup apps disabled (including FW and AV) made no > > difference. > > > > Vista Ultimate (x86) on a custom PC with Intel 975X MB, SATA (AHIC, > > non-raid) HDs and Nvidia 8800 GT video. No hidden/uninstalled updates other > > than language packs. BitLocker pre-config tool installed but BitLocker not > > enabled. > > > > Has anyone encountered this and found a fix? The "I had no problems" voices > > aren't much help. > > > > Scott > > > > "Debbie.Croft@xxxxxx" wrote: > > Quote: > > > I'm running Vista Ultimate (x86) on a Dell laptop. I can't install the two > > > critical updates KB943411 and KB935509. Have shut down firewall/AV and other > > > unnecessary stuff. Also have tried installing them individually. No luck. > > > Never had an update fail before and it's frustrating the hell out of me (and > > > Vista has been doing for a couple of months, really). > > > > > > Anyone had any luck in getting these updates installed? Any advice? > > > > > > |
| | #6 (permalink) |
| | RE: Problems with installing updates KB943411 and KB935509 Oh no! Now I noticed that I used wrong number here. It is KB935509, not KB905866, where my problem is. Just like it reads at subject. Anyway I still try to find a solution. "lolo" wrote: Quote: > Have exactely the same problem and is driving me crazy because I try to > reinstall it a lot of time. > > My laptop is an Acer 7720G and I have windows Vista Ultimate in French. > > Thanks for response to fix the problem. > > "Jari N" wrote: > Quote: > > I have problems too. First all 7 latest updates failed. > > I noticed that KB905866 has different error code than other updates. > > I installed all other but KB905866 and then updating was successful. > > Then I tried to install KB905866 alone. But after several tries KB905866 > > failed every time to error 8000405. > > > > I have Vista Ultimate x64. Athlon X2 4200 and Radeon graphics. > > > > I make searching with Google and find some other people with same problems, > > but no solution yet. Someone think it is bitlocker. I don't understand whole > > Bitlocker at all. I never used it for nothing and I think I don't need it. > > Maybe i still have it in use somewhere in hidden? > > > > > > "smacmillan" wrote: > > Quote: > > > For what it's worth I've the same problem. Using msconfig to start with all > > > non-MS services and all startup apps disabled (including FW and AV) made no > > > difference. > > > > > > Vista Ultimate (x86) on a custom PC with Intel 975X MB, SATA (AHIC, > > > non-raid) HDs and Nvidia 8800 GT video. No hidden/uninstalled updates other > > > than language packs. BitLocker pre-config tool installed but BitLocker not > > > enabled. > > > > > > Has anyone encountered this and found a fix? The "I had no problems" voices > > > aren't much help. > > > > > > Scott > > > > > > "Debbie.Croft@xxxxxx" wrote: > > > > > > > I'm running Vista Ultimate (x86) on a Dell laptop. I can't install the two > > > > critical updates KB943411 and KB935509. Have shut down firewall/AV and other > > > > unnecessary stuff. Also have tried installing them individually. No luck. > > > > Never had an update fail before and it's frustrating the hell out of me (and > > > > Vista has been doing for a couple of months, really). > > > > > > > > Anyone had any luck in getting these updates installed? Any advice? > > > > > > > > |
| | #7 (permalink) |
| | RE: Problems with installing updates KB943411 and KB935509 I re-posted this problem in the Windows Update section of this forum in hope that someone there might see it. Someone did. The suggestion was made to uninstall (not disable via msconfig) Comodo firewall. That did the trick for me. Re-installing afterwards seemed to go fine. Scott "Debbie.Croft@xxxxxx" wrote: Quote: > I'm running Vista Ultimate (x86) on a Dell laptop. I can't install the two > critical updates KB943411 and KB935509. Have shut down firewall/AV and other > unnecessary stuff. Also have tried installing them individually. No luck. > Never had an update fail before and it's frustrating the hell out of me (and > Vista has been doing for a couple of months, really). > > Anyone had any luck in getting these updates installed? Any advice? > > |
| | #8 (permalink) |
| | RE: Problems with installing updates KB943411 and KB935509 KB935509 has something to do with bootloader. I have two harddisks. Disk A I have Vista, Suse 6.3 Linux and Grub-bootloader. This is my normal boot-disk. I have drive B where is XP and Vista own bootloader for XP-Vista (Vista is still on disk A) selection. Today I boot from drive B and KB935509 installed without problems. I select drive A again to my boot-disk and Vista started well. Good, but I wonder what happens to SP1-installation when available. Maybe KB935509 makes something to bootloader and that modification is now on wrong disk. "Jari N" wrote: Quote: > Oh no! Now I noticed that I used wrong number here. It is KB935509, not > KB905866, where my problem is. Just like it reads at subject. Anyway I still > try to find a solution. > > "lolo" wrote: > Quote: > > Have exactely the same problem and is driving me crazy because I try to > > reinstall it a lot of time. > > > > My laptop is an Acer 7720G and I have windows Vista Ultimate in French. > > > > Thanks for response to fix the problem. > > > > "Jari N" wrote: > > Quote: > > > I have problems too. First all 7 latest updates failed. > > > I noticed that KB905866 has different error code than other updates. > > > I installed all other but KB905866 and then updating was successful. > > > Then I tried to install KB905866 alone. But after several tries KB905866 > > > failed every time to error 8000405. > > > > > > I have Vista Ultimate x64. Athlon X2 4200 and Radeon graphics. > > > > > > I make searching with Google and find some other people with same problems, > > > but no solution yet. Someone think it is bitlocker. I don't understand whole > > > Bitlocker at all. I never used it for nothing and I think I don't need it. > > > Maybe i still have it in use somewhere in hidden? > > > > > > > > > "smacmillan" wrote: > > > > > > > For what it's worth I've the same problem. Using msconfig to start with all > > > > non-MS services and all startup apps disabled (including FW and AV) made no > > > > difference. > > > > > > > > Vista Ultimate (x86) on a custom PC with Intel 975X MB, SATA (AHIC, > > > > non-raid) HDs and Nvidia 8800 GT video. No hidden/uninstalled updates other > > > > than language packs. BitLocker pre-config tool installed but BitLocker not > > > > enabled. > > > > > > > > Has anyone encountered this and found a fix? The "I had no problems" voices > > > > aren't much help. > > > > > > > > Scott > > > > > > > > "Debbie.Croft@xxxxxx" wrote: > > > > > > > > > I'm running Vista Ultimate (x86) on a Dell laptop. I can't install the two > > > > > critical updates KB943411 and KB935509. Have shut down firewall/AV and other > > > > > unnecessary stuff. Also have tried installing them individually. No luck. > > > > > Never had an update fail before and it's frustrating the hell out of me (and > > > > > Vista has been doing for a couple of months, really). > > > > > > > > > > Anyone had any luck in getting these updates installed? Any advice? > > > > > > > > > > |
| | #9 (permalink) |
| | RE: Problems with installing updates KB943411 and KB935509 +1 for me I have to uninstall comodo firewall et reinstall it after update. "smacmillan" wrote: Quote: > I re-posted this problem in the Windows Update section of this forum in hope > that someone there might see it. Someone did. > > The suggestion was made to uninstall (not disable via msconfig) Comodo > firewall. That did the trick for me. Re-installing afterwards seemed to go > fine. > > Scott > > "Debbie.Croft@xxxxxx" wrote: > Quote: > > I'm running Vista Ultimate (x86) on a Dell laptop. I can't install the two > > critical updates KB943411 and KB935509. Have shut down firewall/AV and other > > unnecessary stuff. Also have tried installing them individually. No luck. > > Never had an update fail before and it's frustrating the hell out of me (and > > Vista has been doing for a couple of months, really). > > > > Anyone had any luck in getting these updates installed? Any advice? > > > > |
| | #10 (permalink) |
| | Re: Problems with installing updates KB943411 and KB935509 I kept getting the same failure notice since I got this update on 08 Jan 2008. It caused all the updates to fail on Windows Vista 32 bit Home Prem, however I isolated the problem update to this one by installing each seperately unitil I was left with KB941411. I have gone to http://support.microsoft.com/kb/943411 and found what appears to be the answer and will be trying it out in a moment or two. I've copied it below for your info. Known Issues with the Windows Sidebar Protection update The Windows Sidebar Protection update may not uninstall if the Shared Gadgets folder contains only the Sidebarlock.dat file. To work around this problem, follow these steps: 1. Click Start, type %programfiles%\Windows Sidebar\Shared Gadgets in the Start Search box, and then click Shared Gadgets in the Programs list. 2. On the File menu, point to New, and then click Folder. Type any name for the folder. For example, type Test for the name of the folder. 3. Try again to uninstall the Windows Sidebar Protection update. For more information about the Windows Sidebar Protection update, click the following article number to view the article in the Microsoft Knowledge Base: 941411 (http://support.microsoft.com/kb/941411/) Windows Sidebar Protection update for Windows Vista -- petedavo ------------------------------------------------------------------------ petedavo's Profile: http://forums.techarena.in/member.php?userid=39425 View this thread: http://forums.techarena.in/showthread.php?t=888860 http://forums.techarena.in |
| Problems installing updates for Vista x64 Ultimate | Windows Updates | |||
| Update KB943411 | Vista General | |||
| Problem installing KB935509 | Vista security | |||
| problems after installing updates..no sound, can't hibernate, scrn | Vista General | |||
| problems installing iTunes updates | Vista General | |||
