Vista - Media Player won't open, not running as process in background
Old 01-10-2008   #1 (permalink)
MK
Whenever i attempt to open WMP nothing happens. monitoring the processes
while opening it i discovered that it was in fact opening for a split second
and then being terminated.
I tried the windows fix where you;
1. Click Start, click Run, type regsvr32 jscript.dll, and then click OK.
2. Click Start, click Run, type regsvr32 vbscript.dll, and then click OK.
But i need to do this every time i start windows. Is there no permanent
solution to this problem?
Old 01-20-2008   #2 (permalink)
zachd [MSFT]
Re: Media Player won't open, not running as process in background
Wait, so that *does* temporarily fix it up? That would imply that either
your registry is corrupt or that something is actively resetting these
settings incorrectly. =\
Speaking for myself only.
See http://zachd.com/pss/pss.html for some helpful WMP info.
"MK" <MK@xxxxxx> wrote in message
news:159AB066-8E39-4213-A0E6-07D7FA077240@xxxxxx
> second
Can't open Mail but it's running in the background Vista mail
Meda Player process starting in background - can't play videos Vista music pictures video
Media player doesn't display media plays in background Vista music pictures video
Media Player 11 - doesn't open window when running movie file Vista music pictures video
annoying process running in background Vista General
