| | How to edit shell commands? I'd like to edit a shortcut link supplied by a software vendor... in windows xp, shell commands (like show desktop) were a fairly simple text file with ..scf extension, and were easily edited... In Vista, however, unless I am doing something wrong, sending the shortcut link to notepad results in scrambled looking code... is there a new type of shell command handling in Vista? Thanks |
| Registry edit User shell help, Could Microsoft's answer be wrong? | Vista file management | |||
| Can parent shell monitor run/crash status of Child shell/exe ? | PowerShell | |||
| where is the undo/edit commands on vista word and XL | Vista General | |||
| Executing Power Shell Scripts from Windows Shell | PowerShell | |||
