Vista - will Windows marketplace 32bit vista key work with the same 64bit
Old 01-10-2008   #1 (permalink)
ERM
will Windows marketplace 32bit vista key work with the same 64bit edition
Old 01-10-2008   #2 (permalink)
Brian Bradley
Re: will Windows marketplace 32bit vista key work with the same 64bit
"ERM" <ERM@xxxxxx> wrote in message
news:2631DCB7-A8EB-4AC7-92CA-A49B924B1FD4@xxxxxx
No. The 64-bit version of even the same Vista edition is a different product
and requires a different product key.
Old 01-10-2008   #3 (permalink)
Andre Da Costa[ActiveWin]
Yes, the product key for the 32 bit version of Vista also works with the 64
bit version, the thing is, if you already have 32 bit Vista installed, you
have to remove it first the install 64 bit Vista with that same key and it
most cases reactivate.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
Old 01-10-2008   #4 (permalink)
Brian Bradley
What's the emoticon for blushing face? I knew the correct answer. I was
thinking of something else.
Will my 64bit activation key work for 32bit Vista? General Discussion
64bit PC MACHINE, X86 WINDOWS,CAN I have 32bit & 64bit vista partitions General Discussion
32bit apps crash when attempting to get online, 64bit programs work fine. Vista networking & sharing
will Windows marketplace 32bit vista key work with the same 64bit Vista installation & setup
32bit apps crash when attempting to get online, 64bit programs work fine. Vista General
