Vista - Start Menu "right" click context menu
Old 01-11-2008   #1 (permalink)
vegaspat
How do you delete items on the context menu when you right click the Start
Menu?
I did find some information and was able to delete a couple of them in the
Registry.(VERY CAREFULLY)
But I know that some are apparently not able to be deleted such as Open,
Explore and Search. But there are two left that I can't find any info on
deleting them.
They are: Add to 'Windows Media Player List and Play with Windows Media
Player.
I would appreciate any suggestions or help.
Thanks.
Old 01-16-2008   #2 (permalink)
Ramesh, MS-MVP
Re: Start Menu "right" click context menu
Manage the context-menu entries for files, folders, drives and Namespace objects:
http://windowsxp.mvps.org/context_folders.htm
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
Windows® Troubleshooting http://www.winhelponline.com
"vegaspat" <vegaspat@xxxxxx> wrote in message news:2E72ED76-7397-4837-901C-D73E1DAC7633@xxxxxx
Menu?
deleting them.
Player.
Thanks.
Solved "Open With" command disappeared completely from File Context Menu General Discussion
Open IME" & "Reconversion" option on context menu, How do I remove Vista General
How do I remove "Restore previous versions" from my context menu? General Discussion
Start Menu - when I click on the "pictures" button nothing happens Vista file management
the right click context menu "new" Vista General
