| Guest | No bluetooth control panel I'm trying to install a Kensington bluetooth dongle. I don't have a control panel for bluetooth, nor do I have "my bluetooth places" anywhere. The device manager shows the kensington driver is installed and says it is working properly. How do I get the bluetooth control panel so I can add and configure hardware for bluetooth devices? |
| Guest | Re: No bluetooth control panel For Bluetooth troubleshooting suggestions, open Vista's "Help and Support" and type "Bluetooth" in the Search Help box, then press the Enter key located on your keyboard. -- Carey Frisch Microsoft MVP Windows Shell/User --------------------------------------------------------------- "John Graser" wrote: I'm trying to install a Kensington bluetooth dongle. I don't have a control panel for bluetooth, nor do I have "my bluetooth places" anywhere. The device manager shows the kensington driver is installed and says it is working properly. How do I get the bluetooth control panel so I can add and configure hardware for bluetooth devices? |
| Guest | Re: No bluetooth control panel I have done that. It references using either a control panel for bluetooth devices or "My Bluetooth Places." I don't have either one on my Vista laptop. How do I get them? The device manager says bluetooth is installed and working properly. I can't access anything to change settings for bluetooth. In checking startup services and processes, bluetooth is set to automatically startup and says they are currently running, including the tray icon exe. There is nothing in the system tray referencing bluetooth. From the start menu, typing Bluetooth displays a bluetooth program, but selecting it and hitting enter doesn't do anything at all. The hour glass flashes momentarily, but no program or control panel opens up. "Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message news:A30F3AC4-9D44-4E0B-93D0-28D7B9A33E71@xxxxxx Quote: > For Bluetooth troubleshooting suggestions, open Vista's > "Help and Support" and type "Bluetooth" in the Search Help box, > then press the Enter key located on your keyboard. > > -- > Carey Frisch > Microsoft MVP > Windows Shell/User > > --------------------------------------------------------------- > > "John Graser" wrote: > > I'm trying to install a Kensington bluetooth dongle. I don't have a > control > panel for bluetooth, nor do I have "my bluetooth places" anywhere. The > device manager shows the kensington driver is installed and says it is > working properly. How do I get the bluetooth control panel so I can add > and > configure hardware for bluetooth devices? > |
| Guest | Re: No bluetooth control panel Download BlueSoleil 5.0 http://www.bluesoleil.com/ Also See: http://www.bluetooth.com/Bluetooth/P...structions.htm -- Carey Frisch Microsoft MVP Windows Shell/User --------------------------------------------------------------- "John Graser" wrote: I have done that. It references using either a control panel for bluetooth devices or "My Bluetooth Places." I don't have either one on my Vista laptop. How do I get them? The device manager says bluetooth is installed and working properly. I can't access anything to change settings for bluetooth. In checking startup services and processes, bluetooth is set to automatically startup and says they are currently running, including the tray icon exe. There is nothing in the system tray referencing bluetooth. From the start menu, typing Bluetooth displays a bluetooth program, but selecting it and hitting enter doesn't do anything at all. The hour glass flashes momentarily, but no program or control panel opens up. "Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message news:A30F3AC4-9D44-4E0B-93D0-28D7B9A33E71@xxxxxx Quote: > For Bluetooth troubleshooting suggestions, open Vista's > "Help and Support" and type "Bluetooth" in the Search Help box, > then press the Enter key located on your keyboard. > > -- > Carey Frisch > Microsoft MVP > Windows Shell/User > > --------------------------------------------------------------- > > "John Graser" wrote: > > I'm trying to install a Kensington bluetooth dongle. I don't have a > control > panel for bluetooth, nor do I have "my bluetooth places" anywhere. The > device manager shows the kensington driver is installed and says it is > working properly. How do I get the bluetooth control panel so I can add > and > configure hardware for bluetooth devices? > |
| Guest | RE: No bluetooth control panel "John Graser" wrote: Quote: > I'm trying to install a Kensington bluetooth dongle. I don't have a control > panel for bluetooth, nor do I have "my bluetooth places" anywhere. The > device manager shows the kensington driver is installed and says it is > working properly. How do I get the bluetooth control panel so I can add and > configure hardware for bluetooth devices? > > |
| | #6 (permalink) |
| Guest | RE: No bluetooth control panel I have the same problem with XP. Did you ever get a resolution?..... thanks ...bill "John Graser" wrote: Quote: > I'm trying to install a Kensington bluetooth dongle. I don't have a control > panel for bluetooth, nor do I have "my bluetooth places" anywhere. The > device manager shows the kensington driver is installed and says it is > working properly. How do I get the bluetooth control panel so I can add and > configure hardware for bluetooth devices? > > |
| | #7 (permalink) |
| Guest | Re: No bluetooth control panel Open Vista's Help and Support and in the Search box type: BLUETOOTH and press the enter key on your keyboard. Then click on the various Bluetooth topics. -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows Vista Enthusiast --------------------------------------------------------------- "Bill Bertram" wrote: in message news:8BE88A48-AD3B-4B2F-83A8-B35317122F15@xxxxxx "John Graser" wrote: Quote: > I'm trying to install a Kensington bluetooth dongle. I don't have a control > panel for bluetooth, nor do I have "my bluetooth places" anywhere. The > device manager shows the kensington driver is installed and says it is > working properly. How do I get the bluetooth control panel so I can add and > configure hardware for bluetooth devices? > > |
| | #8 (permalink) |
| Guest | Re: No bluetooth control panel "Bill Bertram" <Bill Bertram@xxxxxx> wrote in message news:8BE88A48-AD3B-4B2F-83A8-B35317122F15@xxxxxx Quote: > > > "John Graser" wrote: > Quote: >> I'm trying to install a Kensington bluetooth dongle. I don't have a >> control >> panel for bluetooth, nor do I have "my bluetooth places" anywhere. The >> device manager shows the kensington driver is installed and says it is >> working properly. How do I get the bluetooth control panel so I can add >> and >> configure hardware for bluetooth devices? >> I today installed a Targus bluetooth USB adapter/dongle and the software it came with installed or created a control panel Icon. The bluetooth CPL was not there prior to the install. I would think there should be something similar provided by Kensington Also you may want to switch control panel to the classic view to see if it shows up there Bill Vista home premium |
| | #9 (permalink) |
| Guest | Re: No bluetooth control panel I need to find the Bluetooth Device Manager in WXP2. I have tried Control Panel, Desktop Search, Help etc. I have a BlueSoleil dongle and the drivers installed and paired OK with mobile phone but it is only partly working, eg. the File Transfer Wizard does not recognise its existence. Where is this Manager which is referred to in Help and in postings, please? -- clayto "Carey Frisch [MVP]" wrote: Quote: > Open Vista's Help and Support and in the Search box type: BLUETOOTH > and press the enter key on your keyboard. Then click on the various Bluetooth topics. > > -- > Carey Frisch > Microsoft MVP > Windows Desktop Experience - > Windows Vista Enthusiast > > --------------------------------------------------------------- > > "Bill Bertram" wrote: > > in message news:8BE88A48-AD3B-4B2F-83A8-B35317122F15@xxxxxx > > > "John Graser" wrote: > Quote: > > I'm trying to install a Kensington bluetooth dongle. I don't have a control > > panel for bluetooth, nor do I have "my bluetooth places" anywhere. The > > device manager shows the kensington driver is installed and says it is > > working properly. How do I get the bluetooth control panel so I can add and > > configure hardware for bluetooth devices? > > > > |
| | #10 (permalink) |
| Newbie | Re: No bluetooth control panel I recently installed a BlueSoleil dongle and had the same problem. Before the installation I could enter the Bluetooth Devices window provided in the Control Panel. After the installation it no longer worked, the mouse would just flash momentarily and stop. This wouldn't have been a problem if the BlueSoleil software wasn't useless. So I started digging around and found under Services the Bluetooth Support Services stopped and it's startup type Disabled. I changed it to back to automatic (I'm thinking the BlueSoleil install altered it) and it has worked fine since. In fact, I went back and uninstalled the BlueSoleil software and am just using the Windows Bluetooth Devices application. Last edited by brandrew; 05-11-2008 at 08:39 AM.. |
| Bluetooth Device Control Panel Share Tab? | Vista General | |||
| Bluetooth Device Control Panel Share Tab | Vista networking & sharing | |||
| No Bluetooth in Control Panel | Vista General | |||
| RC1: No bluetooth item in Control Panel. | Vista hardware & devices | |||
| No Bluetooth Devices in Control Panel | Vista hardware & devices | |||
