The taskbar tells me my system is downloading something, (the downloading
ICON has been running for the past Hr.). How can I tell just what it is
downloading?
downloading?
Is it the Windows Update icon? If so, click Start > All Programs > Windows
Update > View Updates and you will see a list of the available update it
might be downloading.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"LMPIPER" <LMPIPER@xxxxxx> wrote in message
news:3B2480FC-1D73-44F9-B941-2F5A3C8C4381@xxxxxx
> downloading?
Thanks for your reply.
No it WAS not the Windows Update Icon. It WAS a circular arrow rotating
clockwise. When I put the cursor on it a message window said Downloading. It
would not respond to a left or right click. The task manager did not show any
application running. Disconecting from the internet, (unpluging the telephone
line) did not stop it. I usually hibernate and remove power when I leave my
system and it was there when I returned. It went away after a shut down,
(which I just did). I don't have the problem any longer but still don't know
what the system was doing.
Again thanks for the reply.
Leo
> Andre
> news:3B2480FC-1D73-44F9-B941-2F5A3C8C4381@xxxxxx>
> > downloading?
Try running Windows Defender, or any Antivirus... Maybe it will find
something!
Emil Lulic
news:A6630BCC-1063-4657-985F-AAE969134F04@xxxxxx
> It
> any
> telephone
> my
> know
> Leo
>> Windows
>> Andre
>> news:3B2480FC-1D73-44F9-B941-2F5A3C8C4381@xxxxxx>>
>> > downloading
>> > downloading?
Do you have any kind of television component attached to your computer?
My computer will download TV listings to use with Media Center and an HD tv
USB thing I use.
But it doesn't take that long.
> downloading?
If you have McAfee Security, a red arrow in the notification area will circle
around until the McAfee Security has updated itself.
> Leo
> > Andre
> > news:3B2480FC-1D73-44F9-B941-2F5A3C8C4381@xxxxxx> >
> > > downloading?
Open the Run command (Windows Key + R) > type in MSCONFIG > click OK > go to
the Startup (tab) > look for any suspicious icons that could be associated
with the spinning arrow you are seein the notification area. To be honest
with you though, a screenshot would greatly help with this one.
Andre
> It
> any
> telephone
> my
> know
> Leo
>> Windows
>> Andre
>> > downloading
>> > downloading?
| Similar Threads | ||||
| i have problems dowloading anything! | bostonsox | General Discussion | 1 | 06 Feb 2010 |
| Dowloading newsgroup messages | Larry Davis | Vista mail | 0 | 06 Sep 2008 |
| DOWLOADING PROGRAMS FROM INTERNET ON VISTA | DIRECTORY NOT FOUND | Vista General | 3 | 21 Oct 2007 |
| Dowloading Files Under Parental Control | Mouse14 | Vista General | 1 | 01 Oct 2007 |
| Windows Vista and Dowloading Security Updates | LUCKY | Vista General | 0 | 21 May 2007 |
